What Can I Do To A 10Hp Kohler
5 replies to this topic
#1 searspullingtractor OFFLINE
searspullingtractor
  • 34 Thanks
  • 103 posts
Posted October 24, 2013 - 11:03 PM
what can I do to the max
#2 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted October 24, 2013 - 11:19 PM
Any kind of performance you want. Are you trying to make a pro stock engine or what? If you are I wouldn't dump the money into a 10hp. Id go with a 14hp or a 16hp kohler and go from there.
#3 searspullingtractor OFFLINE
searspullingtractor
  • 34 Thanks
  • 103 posts
Posted October 24, 2013 - 11:31 PM
not a pro stock just mod the motor up. any good sites?
#4 baerpath OFFLINE
baerpath
  • 314 Thanks
  • 514 posts
Posted October 25, 2013 - 04:45 AM
This is assuming your using a Kohler
offset bore it, deck the block change to a better head and shave it, get a cam for it, do a good valve job on it, if rules allow it take the #26 carb and swap it for a #28 and put a steel flywheel on it,  You could port the intake slightly but unless your going to crank the rpms that won't do much
#5 JDBrian OFFLINE
  • 9,642 Thanks
  • 14,157 posts
Posted October 25, 2013 - 05:05 AM
Do an online search for Killer Kohler and you should come up with a series of articles on building up a K series engine and a bunch of links as well.
#6 Kyocum OFFLINE
Kyocum
  • 299 Thanks
  • 424 posts
Posted October 25, 2013 - 10:32 AM
His website is Kirk engines . com. He is a great guy to deal with. He has a nice tutorial on building up a k241 and also a k301. Nice pics to view. It pretty much walks you through the whole build process.I just got done building up a k301 from his directions. Cant wait to get it in a tractor and see how it performs. P.S. get your check book out.
