Case 646 Repower
case 646 repower kohler
20 replies to this topic
#16 Case-Closed OFFLINE
Case-Closed
  • 290 Thanks
  • 149 posts
Posted November 24, 2013 - 05:11 PM
The old cooler was still in place but damaged and leaking and of course no fan. I tried to follow the "70" series of tractors that followed the 646 with cooler location, and I hope it works ok. I would like to know what the temp of the hydraulic system should be during operation. I am not certain that the air flow across my oil cooler will be adequate or will I need to install a fan.
  • gopher said thank you
#17 gopher OFFLINE
gopher
  • 749 Thanks
  • 752 posts
Posted November 24, 2013 - 07:44 PM
They say case runs a little hotter 180 deg. high normal.
#18 Mjoe7 OFFLINE
Mjoe7
  • 173 Thanks
  • 172 posts
Posted November 24, 2013 - 09:02 PM
I would highly recommend a fan. A fan that pulls the air through rather than blows air through it is best for heat exchangers. This is how all cars are equipped with a shroud. but anything is better than nothing.
#19 Case-Closed OFFLINE
Case-Closed
  • 290 Thanks
  • 149 posts
Posted November 25, 2013 - 08:45 PM
I'm set up so the Kohler pulls air through the oil cooler but I have a fan that could easily be added if need be. I did discover though that cold weather starting is going to be a problem. I tried to start the tractor this morning at 17 degrees and it would not go. I suspect a brand new engine coupled to a brand new pump might have something to do with it. I intend to put a stick on oil heater on the hydraulic tank to see if that solves the problem unless someone has a better idea that has worked for them.
#20 Mjoe7 OFFLINE
Mjoe7
  • 173 Thanks
  • 172 posts
Posted November 26, 2013 - 03:24 AM
You should be in good shape then for cooling.
I have heard guys covering the tractor and placing a heat lamp or 100 watt light bulb under the tractor to keep it warm. This needs to be maintained when not in use though.
Also make sure you have a lighter grade oil in everything including the engine. A synthetic oil flows much better in cold weather. I've started my old Onan's in much colder weather than 17* before so that should not be an issue. I had Amsoil Synthetic 10w30 in the engine and Amsoil15w40 in the hydriv.
It could be that its taking awhile to get gas, sometimes priming the carb with a shot of fuel before starting gets thing fired up quicker.
I hope it all works out for you. :thumbs:
  • Case-Closed said thank you
#21 Case-Closed OFFLINE
Case-Closed
  • 290 Thanks
  • 149 posts
Posted November 27, 2013 - 11:42 AM
A good friend of mine runs several diesel vehicles and he uses a Katz stick on heater on each and all of them. The surface must be squeaky clean for them to stick but he swears by them. I think I might try the magnetic heaters first since I just happen to have a 500 watt unit in house. It would make sense  that once the new engine and pump have a chance to wear in a bit the starting problem will fix itself.
Edited by Case-Closed, November 27, 2013 - 11:44 AM.
Also tagged with one or more of these keywords: case, 646, repower, kohler
