Case 444 Snow Plow, Do I Have Everything I Need?
25 replies to this topic
#16 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,822 Thanks
  • 2,324 posts
Posted October 26, 2013 - 01:01 PM
I'm assuming that's the lift plate from the photos I'm seeing. If it is, then I just need the front piece correct?
#17 gopher OFFLINE
gopher
  • 742 Thanks
  • 746 posts
Posted October 26, 2013 - 06:56 PM
Sorry but no the adapter plate bolts to that. Your snow blower over the axle hooks to that pin there but your blade lift bar hooks lower under the frame.
#18 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,822 Thanks
  • 2,324 posts
Posted October 26, 2013 - 07:13 PM
Thank you. I've been online all day looking for these parts with 0 luck. I signed up for 3 more forums just to post in the WTB too.
I hope these parts show up soon. Figures I get everything running and ready to go, only to run into this roadblock!
#19 gopher OFFLINE
gopher
  • 742 Thanks
  • 746 posts
Posted October 26, 2013 - 08:34 PM
Have you tried Joe's outdoor power on this site he gets in some cases now and then? You might be able to get both parts from him he does have a lot of inventory.
Edited by gopher, October 26, 2013 - 08:41 PM.
#20 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,822 Thanks
  • 2,324 posts
Posted October 26, 2013 - 09:06 PM
Called every sponsor on this site or sent them an email. Weekend, so I figure they're busy or closed. I believe I left Joe a message on the phone today.
#21 Mjoe7 OFFLINE
Mjoe7
  • 172 Thanks
  • 172 posts
Posted October 28, 2013 - 12:17 AM
I have what you need. I'll send you a private message.
Message sent.
Edited by Mjoe7, October 28, 2013 - 12:33 AM.
#22 Mjoe7 OFFLINE
Mjoe7
  • 172 Thanks
  • 172 posts
Posted October 28, 2013 - 12:50 AM
This is the official description of the part from the parts manual.
Plate - adapter lift bracket. Part# C25382
Some look different than others, but they all carry the same function. (small changes over the years)
Here it is being used for a rear sleeve hitch. It bolts on the same way, only the lift arm for the blade will be on the opposite side of the plate, so you will put the safety pin in on the visible side unlike you see here.
A couple I painted. I have black frame GT's hence the black.
Edited by Mjoe7, October 28, 2013 - 01:06 AM.
#23 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,822 Thanks
  • 2,324 posts
Posted October 28, 2013 - 09:46 AM
One piece down, one to go. Circled on the bottom, I need the front piece now:
#24 Mjoe7 OFFLINE
Mjoe7
  • 172 Thanks
  • 172 posts
Posted October 28, 2013 - 01:11 PM
That piece is called a Bracket - Rear Support. Part# C25571
I replied to your p.m.
Edited by Mjoe7, October 28, 2013 - 01:11 PM.
#25 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,822 Thanks
  • 2,324 posts
Posted October 28, 2013 - 06:25 PM
Thank you, I called your contact, no luck :(
#26 Mjoe7 OFFLINE
Mjoe7
  • 172 Thanks
  • 172 posts
Posted October 30, 2013 - 01:11 AM
I got your parts ready for you. I had a plow missing the front bracket and I ended up finding one eventually. Just keep an eye out. I will be looking as well for you.
