Case 444 Snow Plow, Do I Have Everything I Need?
25 replies to this topic
#1 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,836 Thanks
  • 2,331 posts
Posted October 24, 2013 - 06:06 PM
I was lucky enough to find a 54" snow plow that's in good shape. I just don't know how to hook it up correctly or if I have all the required parts. Could you tell me? Thanks!
  • JRJ said thank you
#2 gopher OFFLINE
gopher
  • 761 Thanks
  • 756 posts
Posted October 24, 2013 - 06:26 PM
you need the quick connect face plate.
#3 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,836 Thanks
  • 2,331 posts
Posted October 24, 2013 - 06:32 PM
What is that in the 3rd photo, the orange piece?
#4 gopher OFFLINE
gopher
  • 761 Thanks
  • 756 posts
Posted October 24, 2013 - 06:41 PM
looks like deck face plate the one for the blade has taperd gussets on front sides with holes at bottom to run pin through that your blade arm sets in. If you have welder and some flat stock you could make one out of the one you have. Just ran out and took picture of one to give idea of what talking about.
Edited by gopher, October 24, 2013 - 06:53 PM.
#5 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,836 Thanks
  • 2,331 posts
Posted October 24, 2013 - 06:48 PM
I have a snowblower off of it that came with it, would that have it on there? Would I be able to rob that?
#6 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,836 Thanks
  • 2,331 posts
Posted October 24, 2013 - 06:50 PM
http://gardentractor...-1363046897.jpg
#7 gopher OFFLINE
gopher
  • 761 Thanks
  • 756 posts
Posted October 24, 2013 - 07:04 PM
If it has the ears on bottom with removable pin you should be able to use just remember blower is older style lift bar goes over axle the blade is newer style lift bar goes under axel.
  • Titus and JRJ have said thanks
#8 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,836 Thanks
  • 2,331 posts
Posted October 24, 2013 - 07:06 PM
Thank you, will check. I also have to figure out how to install everything.
#9 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,836 Thanks
  • 2,331 posts
Posted October 24, 2013 - 07:13 PM
Does the piece I'm missing come up for sale at all?
#10 gopher OFFLINE
gopher
  • 761 Thanks
  • 756 posts
Posted October 24, 2013 - 07:39 PM
mostly they come with blade. You could WTB never know someone here might have spare. Do you have a lift plate aka adapter plate,sleeve hitch plate. If not you can find plans on line.
#11 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,836 Thanks
  • 2,331 posts
Posted October 24, 2013 - 09:27 PM
Thank you for your help. When I am creating the ad, what are the official names of the parts I need?
#12 Cat385B ONLINE
    HAZMAT CAT
  • 13,967 Thanks
  • 9,999 posts
Posted October 24, 2013 - 09:51 PM
I don't see a speck of snow in any of your pics. You're going to need that, too.
  • motobreeder and JRJ have said thanks
#13 gopher OFFLINE
gopher
  • 761 Thanks
  • 756 posts
Posted October 24, 2013 - 10:43 PM
It's the rear support bracket.    PLATE - adapter, lift bracket .  Should be tag  for model of blade MODEL J, K, L(54) UTILITY BLADE. That's the only two parts I see you don't have.
#14 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,836 Thanks
  • 2,331 posts
Posted October 25, 2013 - 11:05 AM
Thank you, created an ad here:
http://gardentractor...w-parts-needed/
#15 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,836 Thanks
  • 2,331 posts
Posted October 26, 2013 - 12:48 PM
Is this what the plow would attach to?
