Stp- Seafoam Equivalent?
20 replies to this topic
#1 CRFarnsworth ONLINE
CRFarnsworth
  • 4,727 Thanks
  • 2,160 posts
Posted October 24, 2013 - 05:25 PM
Anyone been using this ?    STP answer to seafoam.  Claims to do the same thging but was $1.50 less than Seafoam.      Rick
Edited by CRFarnsworth, October 24, 2013 - 07:52 PM.
  • JRJ said thank you
#2 KennyP ONLINE
  • 38,491 Thanks
  • 45,979 posts
Posted October 24, 2013 - 05:27 PM
Give it a whirl and let us know how it does!
#3 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,338 Thanks
  • 9,800 posts
Posted October 24, 2013 - 06:15 PM
What you talkin' 'bout Willis??? There is no other Seafoam!
  • hamman and JRJ have said thanks
#4 KC9KAS ONLINE
KC9KAS
  • 5,389 Thanks
  • 4,693 posts
Posted October 24, 2013 - 06:20 PM
:ditto:
:yeah_that:
#5 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,349 Thanks
  • 4,961 posts
Posted October 24, 2013 - 06:44 PM
I noticed last week when I went to buy some SeaFoam that it was $11 for a 16 ounce can.  I used to get a quart for $6.99.
I've went back to using Sta-Bil.  Sta-Bil isn't any cheaper to buy but it goes farther per bottle.
#6 AVB OFFLINE
AVB
  • 138 Thanks
  • 135 posts
Posted October 24, 2013 - 06:53 PM
Seafoam is overrated and overpriced. It is just alcohol, naptha (lighter fluid) and a light oil. What are you trying to accomplish?
#7 KennyP ONLINE
  • 38,491 Thanks
  • 45,979 posts
Posted October 24, 2013 - 07:02 PM
Since I started using Seafoam, I haven't had any fuel related issues. So I'll spend the $ to keep using it!
#8 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted October 24, 2013 - 07:09 PM
Rick:
I have been using Berrymans  B-12 Chemtool. I buy it at Walmart for just under $3.00 a can and it contains toluene which the big boys use in pro paint jobs or so I have been told.
 I first came across it an auto parts store, went to get a carb. cleaner and ended up with this and have been using it ever since. I mix 1-2 oz.  in every gallons of gasoline for the tractor and it has worked good as far as I know for I have not had any related problems.  It appears to be a real good paint remover.
 I also had started out using Seafoam but I made the switch.
Dick
#9 AVB OFFLINE
AVB
  • 138 Thanks
  • 135 posts
Posted October 24, 2013 - 07:13 PM
I like Chemtool as well. I am not saying Seafoam doesn't work, just that there are better or cheaper options.
#10 TomLGT195 OFFLINE
TomLGT195
  • 3,834 Thanks
  • 2,816 posts
Posted October 24, 2013 - 07:21 PM
I use" Fuel Tank Medic"
 I get it at the small engine store. works good with no complaints here ,and is a little less than seafoam.
  • Alc and JRJ have said thanks
#11 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted October 24, 2013 - 10:58 PM
Rick:
Just a bit of trivia concerning toluene. While in munitions in the USAF I learned the words that TNT stand for, tri-nitro-toluene.
Mike
Dick
#12 KC9KAS ONLINE
KC9KAS
  • 5,389 Thanks
  • 4,693 posts
Posted October 25, 2013 - 04:06 AM
Just bought 2 cans of SEAFOAM at Rural King for $6.97 each.
Edited by KC9KAS, October 25, 2013 - 04:06 AM.
#13 grnspot110 ONLINE
grnspot110
  • 4,162 Thanks
  • 2,649 posts
Posted October 25, 2013 - 06:41 AM
I buy Seafoam by the gallon.  Usually around $50/gallon, lasts quite a while, but it'll keep!  ~~  Lowell
#14 daytime dave OFFLINE
  • 4,845 Thanks
  • 6,545 posts
Posted October 25, 2013 - 07:27 AM
I do the same Lowell.  I paid $52.oo for the last gallon just this week at an auto parts store.  I put it in all the gas, even in the truck.
I recently decided to switch to non ethanol for the small engines.  It was fifty cents more a gallon for 91 octane.
Edited by daytime dave, October 25, 2013 - 07:29 AM.
#15 HDWildBill OFFLINE
  • 8,975 Thanks
Posted October 25, 2013 - 08:11 AM
I get Seafoam out of Dollar General for about $6 a can.  I've found Dollar General, at least around here, has some good deals on consumables I use in the shop.
  • KC9KAS, JRJ and Sawdust have said thanks
