Wheel Horse Gt-14 Won't Start
16 replies to this topic
#1 KC9KAS OFFLINE
KC9KAS
  • 5,469 Thanks
  • 4,725 posts
Posted October 24, 2013 - 03:57 PM
My GT-14 (14 hp K series) won't start.
It was flooding bad, so I removed and rebuilt the carb.
After installing the carb I realized I did not install a spacer about 1/4-5/16" thick between the carb and the block. I was told this shouldn't hurt anything.
I have good spark, good compression, and I checked the flywheel key to make sure it wasn't broken.
I have made the initial carb adjustments but can't get this thing to even attempt to start.
It won't even fire on carb cleaner (with fuel shut off).
Any other suggestions?
#2 olcowhand ONLINE
  • 42,900 Thanks
  • 31,942 posts
Posted October 24, 2013 - 04:14 PM
If it's a points style, flywheel key makes no difference, but if solid state, then it will.  The GT14 I had years ago had solid state ignition.  You said it's been flooding in the past.  Did you replace the spark plug?  Even if it looks good, a gas fouled plug can fool you.  Exhaust outlet clear?
  • KC9KAS said thank you
#3 KC9KAS OFFLINE
KC9KAS
  • 5,469 Thanks
  • 4,725 posts
Posted October 24, 2013 - 04:34 PM
Did not replace the plug, but with it removed from the head and the wire connected, the plug fires great....Maybe I will try a new plug.
Really getting to me!
Exhaust is clear.
#4 olcowhand ONLINE
  • 42,900 Thanks
  • 31,942 posts
Posted October 24, 2013 - 05:21 PM
I've also had similar issues starting an engine.  The plug will be good, spark good, and carb in great shape, but won't pick up fuel.  Almost always, I can pull the spark plug, directly spray a decent shot of carb spray into the cylinder, quickly get the plug back in, and they'll fire right up & do fine thereafter.  Why...I don't know!
#5 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,844 Thanks
  • 2,336 posts
Posted October 24, 2013 - 06:12 PM
I too would suggest a spark plug. I've had that same thought pattern that it sparks good, put it in then nothing. I ended up buying a box of NGK spark plugs to have on hand to be safe. 9/10 times it ended up being the spark plug.
#6 KC9KAS OFFLINE
KC9KAS
  • 5,469 Thanks
  • 4,725 posts
Posted October 24, 2013 - 06:23 PM
Going to get a plug (or 2) tomorrow....I will let you know the outcome of this issue...
By the way, how many turns out would you start at after a carb kit installation?
#7 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted October 24, 2013 - 06:40 PM
Usually about  2 turns on the main screw. 1 1/2 on the idle.
#8 Texas Deere and Horse OFFLINE
  • 14,889 Thanks
  • 15,514 posts
Posted October 24, 2013 - 07:00 PM
I start at 1 1/2 turns on both jets and go from there.
#9 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted October 24, 2013 - 07:14 PM
The specs for the carb should be in the Kohler service manual. On second thought I think I have a chart somewhere. I'll attach it here. This is pretty handy with the initial settings for all the K series engines.
#10 olcowhand ONLINE
  • 42,900 Thanks
  • 31,942 posts
Posted October 24, 2013 - 07:48 PM
I do the same.
#11 KC9KAS OFFLINE
KC9KAS
  • 5,469 Thanks
  • 4,725 posts
Posted October 25, 2013 - 04:27 PM
OK guys, YOU ROCK!!
I put a new plug in the Kohler, shot a small squirt of carb cleaner in the intake, and 3 seconds later it was running well enough that no adjustment of the carb was necessary until it warmed up!
I would never have thought that a plug that shows spark could be weak enough to NOT start an engine.
I know better now!
This is what I like about this forum....people helping others!
Thanks again!
  • olcowhand, MH81, OldBuzzard and 2 others have said thanks
#12 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,844 Thanks
  • 2,336 posts
Posted October 25, 2013 - 04:32 PM
Glad to hear it!
#13 CRFarnsworth OFFLINE
CRFarnsworth
  • 5,179 Thanks
  • 2,256 posts
Posted October 25, 2013 - 04:38 PM
OK guys, YOU ROCK!!
I know better now!
Thanks again!
:thumbs:  :dancingbanana:  :thumbs:  :dancingbanana:  :thumbs: Rick
#14 olcowhand ONLINE
  • 42,900 Thanks
  • 31,942 posts
Posted October 25, 2013 - 06:33 PM
Good deal!  :thumbs:
#15 OldBuzzard ONLINE
OldBuzzard
  • 7,097 Thanks
  • 4,817 posts
Posted October 25, 2013 - 06:48 PM
... I would never have thought that a plug that shows spark could be weak enough to NOT start an engine.
I know better now! ...
At one time none of us knew that, so don't bad about it.
That's one reason that something like this is handy.
http://www.amazon.co...r/dp/B000MHNDSM
It will definitely take out the "guessing' if the plug is working or not.
