Hydraulic Pump On A 14G
7 replies to this topic
#1 Jake OFFLINE
Jake
  • 238 Thanks
  • 140 posts
Posted October 24, 2013 - 05:28 AM
I got a 14G with hydraulic lift. Can someone tell me the GPM and PSI this pump will put out? Thanks Jake
#2 shorty ONLINE
shorty
  • 5,481 Thanks
  • 5,261 posts
Posted October 24, 2013 - 07:43 PM
I couldn't find anything on the gpm. The best I found was in the repair manual. For the 931013 model, it looks to be 550 psi is where they have the pressure listed at. All the pressures and cylinder forces are the same as the hydrostatic drive models. Hope this helps.
  • Jake said thank you
#3 Jake OFFLINE
Jake
  • 238 Thanks
  • 140 posts
Posted October 25, 2013 - 07:01 PM
Thanks Shorty
#4 olcowhand ONLINE
  • 41,142 Thanks
  • 31,415 posts
Posted October 25, 2013 - 07:15 PM
I have never seen any hydrostatic drive lift circuit put out more than 2 to 2 1/2gpm.
#5 shorty ONLINE
shorty
  • 5,481 Thanks
  • 5,261 posts
Posted October 26, 2013 - 07:17 AM
I didn't see anywhere what kind of pump they used for this. Since all the specs are the same as the hydros, could they have adapted a hydro pump to it?
#6 Jake OFFLINE
Jake
  • 238 Thanks
  • 140 posts
Posted October 27, 2013 - 12:11 PM
This is a gear drive tractor with a belt driven hydraulic pump. I took the hydraulic system off this tractor for a project I have been working on. Just didn't know what I had to work with Thanks Jake
  • olcowhand said thank you
  • 14,811 Thanks
  • 15,499 posts
Posted October 27, 2013 - 12:19 PM
Does the pump have any kind of tag on it? How about a picture of it.
#8 olcowhand ONLINE
  • 41,142 Thanks
  • 31,415 posts
Posted October 27, 2013 - 01:23 PM
Duh on me!  14"G" should have clued me in!  If there is no tag, then about the only cheap/easy way to determine flow rate is to catch the oil from one revolution of the pump by hand, then measure this amount, then multiply by the rpm you would be running.  So if you got like lets say 4cc of oil (easier to measure with a hypodermic syringe), you convert that to cubic inches.  That comes to .244ci. multiplied by 3600 (rpm)= 878 cubic inches....converted to gallons is 3.8gpm
