Speedex Tractor Repower
23 replies to this topic
#16 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted November 04, 2013 - 03:04 PM
wow thats pretty impressive
  • toomanytoys84 said thank you
#17 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted November 05, 2013 - 09:37 PM
fired her up tonight btu floats stuck will post picture s tommorow on exhausts
#18 bolex OFFLINE
bolex
  • 123 Thanks
  • 313 posts
Posted November 07, 2013 - 07:14 PM
first if you intend to keep that vangard running for any length of time keep the oil filter , it is there to supply clean oil to the bearings without it you WILL have premature catastrophic FAILURE the engine may last a year or because of one tiny piece of grit fry the rods and roach the motor in less than a week of playing around , second go back to the first point and think about it before you run it to long without the oil filter and cause irreversable damage and be looking for another engine . third the speedex trannys have two sizes if you don't have a s23 or 24 find the tranny for one and use it or the shift handle in the smaller s series to heavy up the input side of the tranny , tough but not indestructable , just some points to think on from someone that has several speedex's :thumbs:
#19 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted November 10, 2013 - 02:11 PM
some what finished need to find A GAS TANK
#20 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted November 10, 2013 - 04:47 PM
  • Alc and toomanytoys84 have said thanks
#21 glgrumpy ONLINE
  • 8,742 Thanks
  • 7,982 posts
Posted November 10, 2013 - 04:53 PM
So, what's the clutch? Sliding engine or belt tensioner? I find my Briggs in mine to be kinda "shaky" with moving mount. Not sure if that is how these are or if not tight enough on guides?  Think I have them set pretty good, but not sure what is really acceptable.
  • superspeedex said thank you
#22 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted November 10, 2013 - 05:22 PM
Slideing Engine and yea you got to get them tweaked right losen up the engine on the plate twish the engine to the left and tighten the bolts and that way when you engage the clutch or slide it ahead the engine will be strait or go through and make new mounts for them
#23 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 10,511 Thanks
  • 6,186 posts
Posted November 11, 2013 - 02:17 PM
Looks real good!
#24 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted November 11, 2013 - 02:22 PM
still needs fine tuned gas tank and cover and tank painted might take it to plow days this weekend not sure yet
