Speedex Tractor Repower
23 replies to this topic
#1 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted October 23, 2013 - 07:11 PM
Well ince my briggs cracked and before i got it welded up i found a 16 hp briggs vanguad v twin and i am in the process of putting it in heres some pics..... btw if anyone ha any info or upgrades and stuff that they want to tell me have at it i am not to big into the v twins all i know is i wont run outta power.... o and i ll keep you updated i have to machine exhaust pipes for it and the oil filter relocating plates and air filter bracket
  • Alc, sacsr, LilysDad and 1 other said thanks
#2 glgrumpy OFFLINE
  • 8,848 Thanks
  • 8,035 posts
Posted October 23, 2013 - 08:20 PM
Well looks like the room for it!  Hey, run those exhaust as two stacks or make join into one BIg one!  THAT would be diff on a Speedex. Believe it or not my 96 Speedes 2032 had the Vanguard in it. Always ran nice and smooth. Weird thing tho was shut-off. They key would go off, but tractor keep running about another 10 seconds till the fuel shut-off kicked off and then it stopped. You may have some wiring issues to look at if you have those features. Maybe a wire diagram from later model like I had would help?? There are charging and Lite circuits involved with this engine also, be careful not to burn anything out hooking up wrong. Also a vacumm run fuel pump was on mine, right up by carb on top of engine.
  • superspeedex said thank you
#3 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted October 23, 2013 - 08:28 PM
Yes i ordered a different filter thing so i dont have to relocate it and i ll run the filter right out in frount of the engine but i think what i am going to do is run custom mahchined tube" love the looks of some good work"  and run them strait out and thread the end so i can run strait pipes or muffler i doubt ill connect them i might though well see how it work s out i bet it will sound pretty good. maybe in a bit ill do a 2 barrel converion. O and the fuel pump is my last issue cause i will use the original 8hp tank but have it under the eat so i need to find a 12volt or vacum pump somewhere
  • Cvans and Dieselcubmike have said thanks
#4 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted October 23, 2013 - 10:15 PM
If your looking for upgrades your gonna need some money. Your looking at a high lift cam, high compression heads, bigger valves, bigger carb, advanced timing, those sort of things. Now for the 16hp vanguard I don't know how available those can be. You can have a machine shop do all that. If your pulling with a transfer sled that's one thing, but ive never pulled with a dead weight sled before so im not sure how its going to handle. Its your tractor though and you can set it up how you want I just thought id give a few suggestions :thumbs: best of luck
#5 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted October 24, 2013 - 05:15 AM
yea you can spend some big bucks in these ill probaly leave it as is
#6 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted October 26, 2013 - 11:32 AM
Does any one know if theres a fuel pump built into this engine because i got to relocate gastank and am in need of a pump cause all i got is one of those syphon pump off a 14 hp verticle shaft that hooks to the valve cover and dont kno where it connects on this engine
#7 bolex OFFLINE
bolex
  • 123 Thanks
  • 313 posts
Posted October 27, 2013 - 07:15 PM
stens makes an aftermarket fuel pump for those thats pretty reasonable
#8 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted October 27, 2013 - 08:59 PM
ok What about running an oil filter delete??
#9 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted October 28, 2013 - 07:23 PM
Made a delete looks reall nice but its backwards lol my fault
#10 speedex99gt OFFLINE
speedex99gt
  • 43 Thanks
  • 52 posts
Posted October 29, 2013 - 07:38 AM
Lookin good!
#11 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted October 30, 2013 - 04:31 PM
got a good one made
#12 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 11,117 Thanks
  • 6,475 posts
Posted October 31, 2013 - 01:48 PM
http://www.ombwareho...-Fuel-Pump.html
hook up a pulse fitting, and you are good to go.  I've used this pump on several different set ups on go karts and mini bikes
#13 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted October 31, 2013 - 02:02 PM
Yes where do i hook it up at the valve cover or crancase vent??
#14 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted November 03, 2013 - 06:44 PM
Got the fuel line and pump all setup ran the wiring and all that left is patch the one gas tank and finsh the exhaust and she will be running then i am going to go through and paint the cover and tank
#15 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 11,117 Thanks
  • 6,475 posts
Posted November 04, 2013 - 02:16 PM
Sorry I didn't check this,
I usually put it in the valve cover.  There are other ways, but it accomplishes the same.
That little fuel pump I usually use on my modified Honda 6.5HP Clone engines.  Some of them see some crazy RPMs and fuel needs.  Never been let down by them.  Get those little engines built enough and you can't gravity feed enough.
