Got A 69 - 112 Today
3 replies to this topic
#1 lyall ONLINE
lyall
  • 2,020 Thanks
  • 1,525 posts
Posted October 22, 2013 - 08:42 PM
sorry pictures - got to get a different camera
the 112 is a 69 with a Tecumseh, no deck - got several
it needs a lot of work - but I should most of the past
the motor fills like if has good compress
this is the first Deere I got with Tecumseh in it ( so am going to learn about Tecumseh)
I do have a Kohler 12 hp with Hydraulic lift I might use if I have problem with the Tecumseh
I would like to use it for a 72 -74 112 - have not found one but still looking
also got a cab for the 100 series Deere - no doors or front cover
got it taken apart so the it can be cleaned and paint removed
glass is good
having no doors or front cover - that is okay
for the front cover I will make a metal cover for using heating duct work ( the rectangular duck )
will have to make the doors too using sheet metal and plexaglass
and got an old EZ-Rake thatcher wirh a 3hp B&S
I can use it for parts for mine other one that has the 5 hp B&S on it
or see if I can make it a front mount for one of my Deeres
I have seen picture of them a Deere - now to figure out the pulley size to get the right speed for it
the B&S have a reducer gear box on them - I think they are 6:1 gear ratio
got all 3 for $200
  • hamman and Dieselcubmike have said thanks
#2 Trav1s ONLINE
Trav1s
  • 3,169 Thanks
  • 4,283 posts
Posted October 22, 2013 - 08:57 PM
Congrats!  Are you going for one of every year produced between 1968 an 1974?
This is the Tecumseh info I know - the carb main jet is more valuable than gold.  A quick search on WFM will give you lots of info on the Tecumseh engines.
#3 jimbobbillyray OFFLINE
jimbobbillyray
  • 2,790 Thanks
  • 2,755 posts
Posted October 22, 2013 - 09:47 PM
Awesome!  Sounds like u aquired a great list of stuff!
#4 JDBrian ONLINE
  • 9,606 Thanks
  • 14,142 posts
Posted October 23, 2013 - 04:15 AM
Sounds like a nice tractor Lyall. I hope you will post some pics of the 112 when you get a chance.
