782 Snow Blade Lift Arm
2 replies to this topic
#1 bigspoon OFFLINE
bigspoon
  • 137 Thanks
  • 99 posts
Posted October 22, 2013 - 02:32 PM
The 782D that I just got came with a power angle snow blade, but the PO could not find the lift rod. What lift rod do I use? Can a lift frod from a wide frame fit or does the 82 series take a diff rod.
Sent from my HTC VLE_U using Xparent Red Tapatalk 2
  • JRJ said thank you
#2 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted October 22, 2013 - 03:49 PM
Should be the same as a wide frame rod. 28 inches long.
  • bigspoon said thank you
#3 diesel nut OFFLINE
diesel nut
  • 759 Thanks
  • 455 posts
Posted October 22, 2013 - 09:15 PM
I just checked an 82 series and a wide frame I have at work and the wide frame takes a 1/2 inch rod and the 82 series takes a 5/8 inch rod.  They should be the same lenght with the same bends, so if you have the smaller one you should be able to have it coppied onto the 5/8 rod.                       Stewart
