Bolens 1050
41 replies to this topic
#16 superaben OFFLINE
superaben
    Con Man
  • 7672 Thanks
  • 5677 posts
Posted October 22, 2013 - 06:32 PM
You can't even go to look at a Bolens down here for $125.  :thumbs:  You did well!
Ben W.
  • Justin2655 and MyBolens1053 have said thanks
#17 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted October 25, 2013 - 05:25 PM
Shucks Ben, later this fall/winter, I'll let you look at the 1886 forklift and it won't cost you a cent :D :D :D
  • MyBolens1053 said thank you
#18 NyRedNeck OFFLINE
NyRedNeck
  • 88 Thanks
  • 128 posts
Posted November 02, 2013 - 10:03 AM
I got the 1050 home but did not have time to give it a bath. I had very limited time to tinker with it.  The engine is a TR10 and the sickle bar is a Haban 405.  I tried starting her with my battery charger and the start feature. She turned over fairly slow and I could see no spark at all.  I am not too familiar with the Wisc. engines.  Points looked pretty clean and condensor looks like it was replaced not long ago.But still no spark.
The guy gave me an extra pulley as he was trying to figure out what he was missing to get the sickle bar to line up properly.  Not sure if you can tell from the photos what is not correct.  I appreciate all the help you guys can offer.
IMG_0207_zps0e44ba0f.jpg[/URL]
IMG_0208_zps5e6d6619.jpg[/URL]
IMG_0199_zps6ce69d75.jpg[/URL]
IMG_0196_zpsa0f9a74f.jpg[/URL]
IMG_0210_zps806004ce.jpg[/URL]
Edited by NyRedNeck, November 02, 2013 - 10:04 AM.
  • Nato77, SamMC and MyBolens1053 have said thanks
#19 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1685 Thanks
  • 1354 posts
Posted November 02, 2013 - 10:22 AM
You got a awesome deal on it! It looks to be in great shape. If the engine is original it would be a 1966 model.
Congrats on your great score!!
#20 NyRedNeck OFFLINE
NyRedNeck
  • 88 Thanks
  • 128 posts
Posted November 02, 2013 - 10:47 AM
IMG_0203_zps5d6bc0bc.jpg[/URL]
This is what is left of the ID tag.
  • SamMC and MyBolens1053 have said thanks
#21 NyRedNeck OFFLINE
NyRedNeck
  • 88 Thanks
  • 128 posts
Posted November 02, 2013 - 12:46 PM
I was unable to find the manual for the Haban 405. Can anyone send me a link if it is here?
#22 NyRedNeck OFFLINE
NyRedNeck
  • 88 Thanks
  • 128 posts
Posted November 06, 2013 - 03:21 PM
Hey Guys,
I am hoping to find some time to mess with the 1050 this weekend. As i said I am not too familiar with the Wisc engines.  I currently have no spark, can anyone give me a few tips on troubleshooting the issue?
#23 Kfs35 OFFLINE
Kfs35
  • 408 Thanks
  • 416 posts
Posted November 06, 2013 - 04:19 PM
Check the points first.  Give them a little filing if needed, and gap to .020 (I think, going off memory here).  The ignition system on these are pretty simple, coil, points and condenser.
Download the manual:
http://gardentractor...-repair-manual/
Good luck!
  • NyRedNeck and MyBolens1053 have said thanks
#24 NyRedNeck OFFLINE
NyRedNeck
  • 88 Thanks
  • 128 posts
Posted November 06, 2013 - 04:55 PM
Points were clean but still no spark :(  Will double check the gap.
I was not sure if these Wisc had a magneto.
#25 Kfs35 OFFLINE
Kfs35
  • 408 Thanks
  • 416 posts
Posted November 06, 2013 - 08:42 PM
All of my TRAs have battery ignition.
#26 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted November 06, 2013 - 08:52 PM
Your engine is a TR-10D which used magneto  ignition
The wiring and switch is not OEM which may be one of your problems.
To test the points and mag, disconnect the kill wire to the points to bypass the ignition switch and see if you get spark then.
#27 Kfs35 OFFLINE
Kfs35
  • 408 Thanks
  • 416 posts
Posted November 06, 2013 - 08:58 PM
That's what I get look for not looking at the pictures!
#28 NyRedNeck OFFLINE
NyRedNeck
  • 88 Thanks
  • 128 posts
Posted November 07, 2013 - 09:08 AM
Thanks for the reply.  I don't mean to sound ignorant. I believe there is a wire going from the points to the mag.  Do i discconect that wire on the points side? And if so, When you say bypass the ignition how do i start it then?
#29 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted November 07, 2013 - 10:16 AM
Leave the wire connected from the points box to the magneto, you just need to remove the "kill wire" from the points to the ignition switch.
#30 NyRedNeck OFFLINE
NyRedNeck
  • 88 Thanks
  • 128 posts
Posted November 07, 2013 - 10:20 AM
Thanks again.  Is there a wiring diagram available here?
