What Is It?
11 replies to this topic
#1 DB1 OFFLINE
DB1
  • 289 Thanks
  • 292 posts
Posted October 21, 2013 - 06:52 PM
Hello,
Does anyone know what this tool is used for.
It has a  long wooden handle.
Thanks,
  • Texas Deere and Horse, boyscout862 and oldedeeres have said thanks
#2 CRFarnsworth ONLINE
CRFarnsworth
  • 4,523 Thanks
  • 2,083 posts
Posted October 21, 2013 - 07:23 PM
My first thought was some type of cultivating tool.  Then I thought it might be some type of scythe. Not sure if that is a sweep or a cutting blade.  Then I decided whatever it is was probably connected to some kind of  "Child Labor Law".  :D      Rick
Edited by CRFarnsworth, October 21, 2013 - 07:25 PM.
  • DB1 and oldedeeres have said thanks
#3 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,623 Thanks
  • 9,441 posts
Posted October 21, 2013 - 07:28 PM
It appears as if it holds something up and cuts it off. Maybe an okra eliminator.
  • DB1 said thank you
#4 olcowhand ONLINE
  • 39,676 Thanks
  • 30,972 posts
Posted October 21, 2013 - 07:32 PM
Looks like a cultivator to me.  The shoes slide on the ground, and you adjust the cut depth of the sweep by sliding it up or down, then locking it in place with the bolts.
  • Texas Deere and Horse, DB1, LilysDad and 1 other said thanks
#5 Utah Smitty OFFLINE
Utah Smitty
  • 1,700 Thanks
  • 1,781 posts
Posted October 21, 2013 - 09:35 PM
Yeah, what Daniel said...
Smitty
#6 Texas Deere and Horse OFFLINE
  • 14,724 Thanks
  • 15,469 posts
Posted October 21, 2013 - 09:43 PM
I'm with Daniel, It's to cultivate with by hand. The shoes (Skis) keep it from going too deep while you push it down the rows.
#7 baerpath OFFLINE
baerpath
  • 314 Thanks
  • 514 posts
Posted October 22, 2013 - 07:34 AM
Used for cabbage califlower or other head vegatables.   Goes under the head and cuts the stem off then you can flip the head over a couple rows rather than bending for every head.   Our Amish neighbors did a 3 acre feild of cabbage using one's very simulair
  • MH81, Texas Deere and Horse, CRFarnsworth and 3 others have said thanks
#8 DB1 OFFLINE
DB1
  • 289 Thanks
  • 292 posts
Posted October 22, 2013 - 08:27 AM
Thanks for the comments guys.
Baerpath that makes a lot of sense on the use of this tool.
Candy
#9 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,623 Thanks
  • 9,441 posts
Posted October 22, 2013 - 08:44 AM
Do they sell new ones?
#10 olcowhand ONLINE
  • 39,676 Thanks
  • 30,972 posts
Posted October 22, 2013 - 09:02 AM
But it doesn't appear this type could do that.  The loop is low, and way ahead of the blade.  The head of the plant would snag that loop long before the blade got there.
  • Texas Deere and Horse and DB1 have said thanks
#11 baerpath OFFLINE
baerpath
  • 314 Thanks
  • 514 posts
Posted October 22, 2013 - 10:14 AM
When the handle is raised and the blade adjusted forward some. They would be closer.  I may be wrong but that looks a lot like the one the neighnor used
#12 oldmanmopar OFFLINE
oldmanmopar
  • 125 Thanks
  • 83 posts
Posted June 26, 2014 - 06:09 AM
Coupled with your wife a whip and track spikes on wet grass. One of the first mowers ever made.
