What Year?
9 replies to this topic
#1 Traill95 ONLINE
Traill95
    Traill95
  • 1,848 Thanks
  • 1,013 posts
Posted October 21, 2013 - 05:18 PM
I just got this Simplicity Landlord 2012,
Serial # 003445
Mfg # 2012-990399
Hydro Lift- 2012- 990400
These were on the seat pan behind the seat.
I am trying to find out what year it was made and what motor size it is supposed to have in it.
Any help or direction would be much appreciated. :worship:
Edited by Traill95, October 21, 2013 - 06:23 PM.
  • pwombles and JRJ have said thanks
#2 NUTNDUN OFFLINE
  • 10,339 Thanks
Posted October 21, 2013 - 07:31 PM
I can't help you date it but I am pretty sure it should be a 12 horsepower engine. Not sure what brand engines they used though. I am sure someone with more knowledge will be along to give you the right information on your Simplicity :D
I forgot to mention, is there still a serial tag on the motor? If there is the serial number could also help date the tractor.
  • Traill95 said thank you
#3 olcowhand ONLINE
  • 41,046 Thanks
  • 31,390 posts
Posted October 21, 2013 - 07:35 PM
It will be 12HP Briggs for sure.  Can't help with the year, but achomesteader sure can pin it down.  He'll be here shortly.
#4 olcowhand ONLINE
  • 41,046 Thanks
  • 31,390 posts
Posted October 21, 2013 - 07:36 PM
I think you should find the engine numbers stamped either on the top of the flywheel shroud, or on the side.
#5 pwombles OFFLINE
pwombles
  • 201 Thanks
  • 220 posts
Posted October 21, 2013 - 07:43 PM
serial number of engine should be stamped on shroud. last set of numbers should tell you. first 2 are year, second 2 are month, and third 2 are day. IF you have the original engine. Looks good!
#6 CRFarnsworth ONLINE
CRFarnsworth
  • 4,664 Thanks
  • 2,140 posts
Posted October 21, 2013 - 07:45 PM
Bro. I Found a chart on Simple Tractors.  According to it you have a 1966 with a 12 hp briggs.      You do realize  that  I hadn't bought that tractor yet so I could use Larry for "free storage" until spring.  Is it running yet?   :D    Rick
#7 Traill95 ONLINE
Traill95
    Traill95
  • 1,848 Thanks
  • 1,013 posts
Posted October 22, 2013 - 05:48 AM
He stored it for one winter for you already. You trying to make me feel bad? :boo_hoo:   Not working. :bigrofl:
#8 achomesteader OFFLINE
achomesteader
    GT Fanatic
  • 867 Thanks
  • 2,231 posts
Posted October 22, 2013 - 05:50 AM
The Simplicity 2012 was manufactured in late 1966 thru late 1967. If the engine is original, it should be a Briggs & Stratton 12 hp, model 300421, type 0120-01.
  • olcowhand, KennyP, Traill95 and 1 other said thanks
#9 boyscout862 ONLINE
  • 12,831 Thanks
  • 9,158 posts
Posted October 22, 2013 - 07:14 AM
That is a great tractor and the hydro lift makes it even better. The seat puzzles me. It looks like an AC seat. Good Luck, Rick
#10 Talntedmrgreen OFFLINE
  • 3,273 Thanks
  • 2,306 posts
Posted October 22, 2013 - 11:36 AM
It is an AC seat.  The 700's and some early 725's had a similar seat, without armrests.  All other round and flathood Simplicity tractors (except for Serf, Yeoman, and late Broadmoor's) had the dish-style seat like this:
  • CRFarnsworth and boyscout862 have said thanks
