Bush Hog Wisconsin Starter/generator Questions
20 replies to this topic
#16 NUTNDUN OFFLINE
  • 10,339 Thanks
Posted October 21, 2013 - 08:54 PM
Not looking at one, I have to say the flywheel is towards the rear of the tractor.
I think you might be right. Since the clutch / driveshaft comes straight off the motor there isn't much side load on the crank but on the front where the pto clutch is and the way the belt gets routed there is a lot more side load put on the crank which would explain the motor sitting opposite of what i was thinking.
#17 NUTNDUN OFFLINE
  • 10,339 Thanks
Posted October 21, 2013 - 08:55 PM
Yes, I am still interested in it. I thought you were keeping it to keep the HD 12 Original?
I would probably be dead and gone till I ever get rid of the HD-12 so once that happens I won't give a s___. LOL
#18 Texas Deere and Horse OFFLINE
  • 14,792 Thanks
  • 15,492 posts
Posted October 21, 2013 - 08:58 PM
Thanks George, PM sent..
#19 olcowhand ONLINE
  • 41,012 Thanks
  • 31,378 posts
Cubs have flywheel to the rear, and crank out the front.  Pulley for the starter/gen is mounted on the rear of the pto clutch.  The starter/gens off a Briggs are the correct rotation, but not sure if the briggs mounts will work with the Wisconsin.
#20 Texas Deere and Horse OFFLINE
  • 14,792 Thanks
  • 15,492 posts
Posted October 21, 2013 - 09:02 PM
OK, How about changing rotation of the starter. It should be just a matter of reversing the leads??
#21 olcowhand ONLINE
  • 41,012 Thanks
  • 31,378 posts
Posted October 21, 2013 - 09:03 PM
Nope, the field windings have to be changed out....I asked a pro rebuilder about that.
