Bush Hog Wisconsin Starter/generator Questions
20 replies to this topic
#1 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted October 21, 2013 - 04:24 PM
Is the Delco S/G on the Wisconsin TRA-10D used on the Kohlers or any other engine. I am trying to find out what I have as far as running engines is and I need a Starter for this Hog. I have several of the Delco/Kohler Starters on the shelf.
  • JRJ said thank you
#2 farmerall OFFLINE
farmerall
  • 2,202 Thanks
  • 1,473 posts
Posted October 21, 2013 - 04:29 PM
I think the only big difference between starter generators is the rotation they turn. Some are clockwise and some are counter clock wise depending on the engine and how they are mounted. If they turn the same way I don't see any reason why you couldn't use one from another brand of engine. The only other small difference I can think of would be the pulley on the end might not be the same. The pulleys are easy to change though.
  • Texas Deere and Horse and JRJ have said thanks
  • 14,730 Thanks
  • 15,470 posts
Posted October 21, 2013 - 04:32 PM
Thanks Matt.
#4 Burl OFFLINE
Burl
  • 111 Thanks
  • 43 posts
Posted October 21, 2013 - 04:36 PM
Yes Brian, Rotation and the wisconsin takes the shorter S/G because of the block bracket.
  • 14,730 Thanks
  • 15,470 posts
Posted October 21, 2013 - 04:53 PM
Is the short one used on any particular make tractor with a Kohler?
#6 Burl OFFLINE
Burl
  • 111 Thanks
  • 43 posts
Posted October 21, 2013 - 05:15 PM
Not sure! The inside dim. is approx. 6 1/8. to fit bracket on mine
#7 olcowhand OFFLINE
  • 40,374 Thanks
  • 31,177 posts
Posted October 21, 2013 - 05:38 PM
One of my D4-10's had the shorter S/G, but had bad windings for charging, so I took a longer S/G and put on it.  The bracket for the longer S/G fit right on the Wisconsin block.
#8 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted October 21, 2013 - 08:44 PM
So if I understand you right Daniel, I can borrow one off of one of the Cubs and it should bolt right up? Is the rotation the same, I assume it is but you know what they say about ass/u/me don't you!!
#9 olcowhand OFFLINE
  • 40,374 Thanks
  • 31,177 posts
Posted October 21, 2013 - 08:46 PM
No, the Cub Cadet starters turn wrong direction(CCW)!  You have to have one that drives off the flywheel side (CW rotation).  All the older Cubs I've ever seen drive on the crank output side.
Rotation is as viewed from looking at the pulley end of the starter/gen.
#10 NUTNDUN OFFLINE
  • 10,336 Thanks
Posted October 21, 2013 - 08:49 PM
Brian,
The rotation should be the same. Most engines run counter clockwise from the pto side and clockwise from the flywheel side. Most of the Kohlers in the Cubs are mounted with the flywheel side front along with the starter pulley mounted on the front also. That is the way the Wisconsin is mounted up in the Bush Hogs as well.
  • Texas Deere and Horse and sacsr have said thanks
#11 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
I guess I will have to look at a couple of the Briggs that are on the MW tractors. Thanks Daniel!!
#12 NUTNDUN OFFLINE
  • 10,336 Thanks
Posted October 21, 2013 - 08:51 PM
Daniel has me second guessing myself on how the engines are mounted in the Cubs. It's been so long since that 122 of mine has been together I forget how the engine sat in it. I know I have the rotation right for most engines but not sure now on how the engines sit in the older Cubs.
#13 NUTNDUN OFFLINE
  • 10,336 Thanks
Posted October 21, 2013 - 08:52 PM
Brian,
I have that S12D if you are still interested in it. I am pretty sure the starter generator charged also. I don't know how soon you need it though.
#14 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Not looking at one, I have to say the flywheel is towards the rear of the tractor.
#15 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted October 21, 2013 - 08:53 PM
Brian,
Yes, I am still interested in it. I thought you were keeping it to keep the HD 12 Original?
