Jd 314 Plow Project
38 replies to this topic
#1 nade-em OFFLINE
nade-em
  • 202 Thanks
  • 171 posts
Posted October 21, 2013 - 03:36 PM
I really want to try plowing with my 314.
But it does not have a 3 point hitch
Sooooo, how do i hook up a plow to it ?
I have limited knowledge on how they are actually supposed to work.
I need lots of pics on how they are hooked up and where .
I'm hooked on buying implements for the 314, it seems plenty strong :D
Any help would be greatly appreciated by me, probably not the wife though !
  • Dieselcubmike said thank you
#2 twostep OFFLINE
twostep
    Rockstar
  • 1,988 Thanks
  • 2,539 posts
Posted October 21, 2013 - 03:53 PM
The easiest way would be to get an intergral sleeve hitch.
Like this one:
(right click, properties for pic source)
  • Dieselcubmike and nade-em have said thanks
#3 twostep OFFLINE
twostep
    Rockstar
  • 1,988 Thanks
  • 2,539 posts
Posted October 21, 2013 - 03:54 PM
Of course you also need the plow...
Like this one:
(right click, properties for source)
  • nade-em said thank you
#4 nade-em OFFLINE
nade-em
  • 202 Thanks
  • 171 posts
Posted October 21, 2013 - 04:05 PM
That's exactly like i want!
How does it raise and lower ? Or does it?
#5 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted October 21, 2013 - 04:37 PM
Yes it does. It uses a rod from the existing mower lift cylinder. You can see the lift rod coming through the slot in the rear frame. I have a homemade hitch on my 314. It was on there when I got it. It seems to me there may be some plans floating around for building one.
#6 nade-em OFFLINE
nade-em
  • 202 Thanks
  • 171 posts
Posted October 21, 2013 - 04:47 PM
wouldn't matter to me if it was homemade or factory.
my brother had his ferguson TO 20 out plowing his small garden the other day , looked like alot of fun!
#7 hdg4400 OFFLINE
hdg4400
  • 295 Thanks
  • 358 posts
Posted October 21, 2013 - 06:48 PM
nade-em:
I have a set of plans for an Integral Hitch. They're pretty detailed, and even if you don't follow them exactly, they should give you some ideas on making one. Here they are:
Attached File  93071-BM15764_INTEGRAL_HITCH_SQUARE.pdf   1.6MB   223 downloads
Harlan
  • twostep and nade-em have said thanks
#8 nade-em OFFLINE
nade-em
  • 202 Thanks
  • 171 posts
Posted October 21, 2013 - 06:59 PM
nade-em:
attachicon.gif93071-BM15764_INTEGRAL_HITCH_SQUARE.pdf
Harlan
Thanks Harlan!! Hopefully i can find a plow around here .
#9 hdg4400 OFFLINE
hdg4400
  • 295 Thanks
  • 358 posts
Posted October 21, 2013 - 10:12 PM
Greeting:
In my post about the Integral Hitch, I should have said I'm pretty sure I got those plans from someone's post here at GTTalk.
Harlan
  • Trav1s, twostep and nade-em have said thanks
#10 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted October 28, 2013 - 05:19 PM
The one I've got is not a quick attach like the diagrams. It just bolts on. That's one way to simplify things. You just need 4 holes in the hitch and some bolts. You do loose the ability to quick change the hitch. I didn't think that was an issue until I got a 317 and now to change the hitch out from the 314 it is a bit of work.
#11 nade-em OFFLINE
nade-em
  • 202 Thanks
  • 171 posts
Posted October 28, 2013 - 07:10 PM
JDBrian , can you post a few pics so i can see what your hitch looks like? Thanks :D
#12 DPike43 OFFLINE
DPike43
  • 28 Thanks
  • 24 posts
Posted November 20, 2013 - 11:12 PM
I use my 314 at plow days all the time....They are plenty strong for the job.  I use the exact same integral hitch and plow as shown above.
#13 nade-em OFFLINE
nade-em
  • 202 Thanks
  • 171 posts
Posted November 21, 2013 - 04:33 PM
I've been looking around for the integral hitch on craigslist and ebay.
Holy cow ! I didn't think they would be that expensive . I might have to wait till next summer for this purchase.
  • twostep said thank you
#14 Trav1s ONLINE
Trav1s
  • 3,585 Thanks
  • 4,561 posts
Posted November 21, 2013 - 07:39 PM
If you have the skills and resources building one would be pretty easy with the plans from Harlan.
#15 nade-em OFFLINE
nade-em
  • 202 Thanks
  • 171 posts
Posted November 26, 2013 - 08:09 PM
I might just have to try that as a winter project. I'm fair at welding, my dad is much better than i am.
"Hey dad, what are your plans for this winter? :D "
  • Trav1s said thank you
