Deere 425 Cooling System
5 replies to this topic
#1 truckintyler OFFLINE
truckintyler
  • 90 Thanks
  • 63 posts
Posted October 19, 2013 - 05:30 PM
 got the $400 dollar 425 running today, changed the oil filter, cleaned the carb, new fuel line and removed the old gas.
 new battery and cable ends . it started right up and runs amazing! drives great and i love the power steering.
now the temp gauge after 10 mins of running is only at the bottom of the green. opened the cap and it doesnt look like coolant is moving but its warm in the rad
 lower rad hose is cool to the touch
 is the water pump working? i dont think the thermostat is stuck cause heat is getting to the rad.
  • boyscout862, jd.rasentrac and JRJ have said thanks
#2 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted October 19, 2013 - 05:59 PM
Check and make sure it has fluid in it and then check and make sure it is circulating.
Dick
#3 truckintyler OFFLINE
truckintyler
  • 90 Thanks
  • 63 posts
Posted October 19, 2013 - 06:22 PM
has fluid, its the circulating part im wondering about,
 doesnt look like any movement under the rad cap
#4 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted October 19, 2013 - 07:52 PM
I'm going to send you some info. Check your messages
  • truckintyler said thank you
#5 Alberta Bolens OFFLINE
Alberta Bolens
  • 905 Thanks
  • 378 posts
Posted November 09, 2013 - 10:00 PM
$400 425.  I'm so Jealous!!!
#6 truckintyler OFFLINE
truckintyler
  • 90 Thanks
  • 63 posts
Posted November 10, 2013 - 09:08 PM
yes, it was a steal. but the seller had $$$ and wanted it gone. i was just driving by in the right place right time.
