Kohler Magnum 18 And 20 Question
3 replies to this topic
#1 farmer john OFFLINE
farmer john
  • 1,782 Thanks
  • 906 posts
Posted October 19, 2013 - 10:41 AM
hi guys; i have a bolens gt 20 hydro with a bad motor, running on one cylinder, no compression, has a kohler magnum 20 in it, i found a roper with a kohler magnum 18 for $300, motor is good, would it be a direct and easy switch? my kohler manuels show these motors on the same manuel are they the same , little bigger piston? larger carb? what would be the difference? thanks john
#2 Canawler OFFLINE
Canawler
  • 1,948 Thanks
  • 1,802 posts
Posted October 19, 2013 - 11:38 AM
The 18 and 20 are basically the same engine.  They share op and service manuals.
The bores are the same but the 20 has a longer stroke.
As far as interchangeability, I image the crank snout size and style could be different depending on the spec numbers.
#3 HDWildBill OFFLINE
  • 8,975 Thanks
Posted October 19, 2013 - 12:05 PM
As Canawler said they are basically the same engine.  I would think it would bolt right up and depending on what you are using the tractor for you would only notice a slight down grade in power.
#4 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted October 19, 2013 - 08:06 PM
A small downgrade, but It should definitely have more power than the 20 running on one cylinder!
