Self-Leveling Loader
7 replies to this topic
#1 Moosetales OFFLINE
    Always learning something!
  • 1,088 Thanks
  • 1,284 posts
Posted October 17, 2013 - 11:22 AM
I need some help wrapping my mind around the concept of a self-leveling FEL. In the picture below I've circled a lift cylinder that I suspect is part of the "self-leveling" mechanism but I can't figure out how.
This cylinder is only on the right hand side of the tractor which leads me to deduce it's for that system. Here's a short video clip that shows a Woods self-leveling loader at work.
Thanks for helping me wrap my mind around this concept. Thanks.
  • boyscout862 and JRJ have said thanks
#2 farmerall OFFLINE
  • 2,204 Thanks
  • 1,474 posts
Posted October 17, 2013 - 11:28 AM
I don't know how it works exactly but what I think it does, is keep the bucket level as you raise it in the air. Without this if the bucket was curled all the way back and lift to max height the contents of the bucket could potentially come back onto the machine and/or operator. So something like this doesn't happen.
Edited by farmerall, October 17, 2013 - 11:31 AM.
  • Moosetales and boyscout862 have said thanks
#3 Moosetales OFFLINE
  • 1,088 Thanks
  • 1,284 posts
Posted October 17, 2013 - 11:32 AM
Yes, that's my understanding also. I just can't figure out how it works and whether or not that cylinder is involved. Thanks.
#4 Moosetales OFFLINE
  • 1,088 Thanks
  • 1,284 posts
Posted October 17, 2013 - 11:34 AM
BTW, the tractor in the pic above is a Case 530 Construction King...hence posting it here in the Case forum.
#5 boyscout862 OFFLINE
  • 13,228 Thanks
  • 9,288 posts
Posted October 17, 2013 - 12:39 PM
My Ford 4500 has the auto leveling on the loader. Its an extra valve on the valve bank. I can engage it to keep the bucket at a set level. The Case 530s had a problem with there auto levelers. IF you put it on at the wrong time, the top of the right boom support post would rip off the post. That is why most had a strap of steel wrapped and welded over the top as a field repair. I don't remember how that extra cylinder worked. Good Luck, Rick
#6 glgrumpy OFFLINE
  • 8,652 Thanks
  • 7,941 posts
Posted October 17, 2013 - 05:12 PM
I once tried to make a loader into a fork truck like lift. I wanted leveler to keep load flat. It's all in that upper linkage that runs above the loader arms and pivots at the arm bends and runs down to the bucket. Depending on heights of any of these mount points, the action can change. I had heck of time trying to figure out dimensions to do it correct. I made and remade much of the mounts and pivot points to get right. I DID get it close till about the top 2 ft of lift, it still rocked back some on mine. I think the cylinder in this case is just for those times when you DO want to move the bucket back as it is lifted and not be a leveler. You don't really need a cylinder IF you wanted leveling all the time, but would be best on a loader to be able to choose which way you wanted. If you look at some aftermarket loaders for GT's, they have those extra links I mentioned here and are self-leveling. Johnson comes to mind as one brand. I've seen them on Jacobsen GT's and others in pix around net.
#7 nbent OFFLINE
  • 678 Thanks
  • 539 posts
Posted October 17, 2013 - 07:23 PM
our 680 backhoe has 2 of those cylinders on it and i think they are just lift assist cylinders, to help loads at high heights. we have a jd that the self leveling is done without a valve, it has a linkage on each side that keeps the bucket rams in the same place.
#8 1948kb2 OFFLINE
  • 2 Thanks
  • 1 posts
Posted December 20, 2016 - 03:36 PM
Just reading through these older posts as I am a fairly new member. The cylinder that you had circled does indeed work the self leveling bucket on the loader. It is plumbed in series to the bucket cylinders (If you look close in your picture you can see that the hydraulic lines to the bucket cylinders are plumbed to this small cylinder as well). Raising or lowering the loader cylinders causes movement in this cylinder. This movement in turn displaces the oil in the cylinder. Since the oil can only move through the bucket cylinders or the bucket curl valve, the bucket cylinders move a corresponding amount as the loader arms move maintaining the bucket position throughout loader movement. Thats how it is supposed to work. On our old 580 CK backhoe it never worked all that well but that could simply have been caused by age and wear.
  • Alc and Cvans have said thanks
