One Good Looks Trailer
13 replies to this topic
#1 lyall OFFLINE
lyall
  • 2,015 Thanks
  • 1,524 posts
Posted October 16, 2013 - 11:50 PM
I was over at WFM and saw a good homemade trailer
see the following link
http://www.weekendfr...html?1381981890
KennyP will sure like it
  • Alc, Texas Deere and Horse, IamSherwood and 5 others have said thanks
#2 KennyP ONLINE
  • 37,377 Thanks
  • 45,444 posts
Posted October 17, 2013 - 05:30 AM
That's cool. Like that lift. Thanks!
#3 Alc ONLINE
  • 6,739 Thanks
  • 7,395 posts
Posted October 17, 2013 - 05:31 AM
That's a great looking trailer ! The only thing I would have made different would be to move the dump pivot farther to the rear . The homemade trailer I got with my PK doesn't pivot at the end either and when you have a big load it's a little more of a pain to unload
#4 JDBrian OFFLINE
  • 9,601 Thanks
Posted October 17, 2013 - 05:48 AM
Awesome build on that trailer. The nicest I've seen I think.
#5 IamSherwood OFFLINE
  • 8,390 Thanks
Posted October 17, 2013 - 05:59 AM
He did a nice job on that. A lot of work there.
Not to crazy about the gate latch system though. To many intricate parts exposed
that could easily be damaged. But good engineering there.
#6 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted October 17, 2013 - 08:13 AM
Well thought out and built! Like Kenny I like the dump mechanism. And I agree that the tailgate latch could have been simplified.
I see a lot of room for elements to gum up the works on that one.
As rough as my place is, I would have liked to see tandems on  walking beam axles under that and maybe 5'X8'.
I have a 5X8 (Lyall has seen it) that I often pull with the Big Murray or 318 and it could sure use a dump under it.
Moving mulch I can get a lot of volume, without getting a lot of weight.
Edited by JD DANNELS, October 17, 2013 - 08:20 AM.
#7 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted October 17, 2013 - 08:49 AM
That is one good looking trailer and the color scheme matches up real well.
Dick
#8 Sawdust OFFLINE
Sawdust
  • 5,562 Thanks
  • 3,335 posts
Posted October 17, 2013 - 01:08 PM
After going through that much effort I would have built a larger trailer. I agree too much exposed to the elements on the gate latch. It's still a fine piece of engineering for his own needs.
#9 twostep OFFLINE
twostep
    Rockstar
  • 1,969 Thanks
  • 2,528 posts
Posted October 17, 2013 - 03:36 PM
Very nice looking trailer. I've got plans drawn up for a scaled down tandem dump trailer. One of these days I might actually get to building it... The 4 wheel dump wagon will come first though!
A couple of critiques:
-frame structure is too heavy... unless the plan is to haul boulders in that thing.
-why build fenders over the wheels... why not make the bed wider :)
-the scissor mechanism is WAY too elaborate to gain an extra few degrees of tilt.
-the gate latch release is WAY too elaborate... why not just put second handle like the one that appears to be for a tilt lock
Kudos to the guy for his design work though. It would be a great show piece.
Edited by twostep, October 17, 2013 - 03:51 PM.
#10 twostep OFFLINE
twostep
    Rockstar
  • 1,969 Thanks
  • 2,528 posts
Posted October 17, 2013 - 03:55 PM
Also, why have three grease zerts for the tilt pivots? Only the center section should movable. Right?
#11 KennyP ONLINE
  • 37,377 Thanks
  • 45,444 posts
Posted October 18, 2013 - 06:45 AM
I think the frame would need to be strong to handle the force of the cylinder to dump a heavy load. When mine is full of dirt, it takes a bit to get it started dumping.
#12 KennyP ONLINE
  • 37,377 Thanks
  • 45,444 posts
Posted January 16, 2016 - 10:26 AM
The link is broken.
  • Paulgo said thank you
#13 Cvans OFFLINE
  • 6,450 Thanks
  • 6,051 posts
Posted January 16, 2016 - 11:27 AM
The link is broken.
You Got that right.
#14 Cat385B ONLINE
    HAZMAT CAT
  • 13,776 Thanks
  • 9,918 posts
Posted January 16, 2016 - 01:05 PM
Probably from when WFM switched servers and everything got all mixed up.
