How Can I Stop That Clang Clang Clang?!
10 replies to this topic
#1 CubHorse80 OFFLINE
CubHorse80
  • 159 Thanks
  • 318 posts
Posted October 14, 2013 - 06:52 AM
When the clutch is pressed in on my 1200, the clutch rattles and clangs like crazy. but when it is engaged, to move, it does not. I saw that it is the center disk moving around like crazy, and i want to know how to stop it. Do i rebuild it? Do i get the anti rattle springs? do i need a new fiber disk? WHATS NEEDED TO STOP THIS INSANITY???
THIS NOISE IS DRIVING ME CRAZY!!!!!
:wallbanging: :wallbanging: :wallbanging: :wallbanging: :wallbanging: :wallbanging: :wallbanging: :wallbanging:
Also, when i am moving, the tractor vibrates do to the drive shaft and connectors out of alignment. How do i fix this?
Edited by RallyRoperGT18, October 14, 2013 - 06:54 AM.
  • Dieselcubmike and JRJ have said thanks
#2 boyscout862 ONLINE
  • 12,850 Thanks
  • 9,171 posts
Posted October 14, 2013 - 07:32 AM
Check in our Manuals Section for instructions. Good Luck, Rick
#3 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted October 14, 2013 - 07:51 AM
Sounds like the ISO mounts are bad. You should probably take the clutch and driveshaft apart too. The pilot bearing or throwout bearing may be bad. New ISO mounts here.  http://www.ebay.com/...=item2c6353ccca
#4 CubHorse80 OFFLINE
CubHorse80
  • 159 Thanks
  • 318 posts
Posted October 14, 2013 - 08:12 AM
If thats the case, im gonna wait till grass is done growing... Then ill take the engine out, weld that support in on the engine brakcets, replace iso mounts, and update clutch.
What all should i do to the clutch
#5 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted October 14, 2013 - 10:20 AM
Probably resurface the clutch plates, replace the fiber disc and replace those 2 bearings.
  • CubHorse80 said thank you
#6 CubHorse80 OFFLINE
CubHorse80
  • 159 Thanks
  • 318 posts
Posted October 14, 2013 - 10:53 AM
which bearings?
#7 diesel nut ONLINE
diesel nut
  • 700 Thanks
  • 427 posts
Posted October 14, 2013 - 11:51 AM
The rattle in the clutch is due to the fact that the spider springs are missing.  The clutch needs to come out to replace them correctly.  When your in there like the others said check the disk, plates, throw out bearing, teaser spring, and the bushing on the back side of the clutch plate with the three pins in it.                  Stewart
#8 CRFarnsworth OFFLINE
CRFarnsworth
  • 4,668 Thanks
  • 2,143 posts
Posted October 14, 2013 - 04:06 PM
YEP.   What they said.  :iagree:   Rick
#9 Grumpy OFFLINE
Grumpy
  • 721 Thanks
  • 617 posts
Posted October 14, 2013 - 05:57 PM
Just my 2 cents worth, I would put solid mounts in it if take it all apart.
Grumpy
#10 CubHorse80 OFFLINE
CubHorse80
  • 159 Thanks
  • 318 posts
Posted October 14, 2013 - 07:11 PM
Grumpy
But i dont want vibration and i want it quiet.
#11 4SPEED OFFLINE
4SPEED
  • 6 Thanks
  • 22 posts
Posted October 17, 2013 - 09:25 PM
the clutch sound has nothing to do with you ISO mounts. sounds like a new teaser spring and clutch disk and bearing.
