Time To Put A Heli Coil In The Kohler K-341 Head
kohler heli coil spark plug k341
4 replies to this topic
#1 NUTNDUN OFFLINE
  • 10,353 Thanks
Posted October 14, 2013 - 06:16 AM
I got everything back together on the Kohler K341 last weekend and got it fired up. I knew from before that the spark plug hole didn't have the best threads and sure enough when I put it back together this time I didn't like how it tightened up. I should have just redid the spark plug hole with a heli coil from the get go before running it but that is besides the point now LOL.
I used the Bush Hog yesterday to pull the garden trailer and haul firewood from the one corner to our pallets that we have set down to stack it. After I got done with moving most of it I pulled it down to the garage to put air in the tires for the trailer. I have the carb close to proper tune but haven't done the whole thorough tuning yet since it was just put back together I don't want to rev it too high yet.
I had it idling and it started loading up and till I got to it and had a chance to give it a little throttle she backfired and shut off. I just turned the key off and didn't think much of it. Went in to the garage to grab a screwdriver to adjust the mixture screws. Lifted the hood and seen the spark plug hanging from the coil wire. Definitely needs the heli coil done now LOL.
I got the head off yesterday and will be getting the heli coil done this week yet. Would like to be able to use the tractor again next weekend.
  • Alc, Texas Deere and Horse, boyscout862 and 2 others have said thanks
#2 MH81 OFFLINE
  • 29,979 Thanks
Posted October 14, 2013 - 06:20 AM
Sorry to hear it George, but at least you can fix it.
Keep an eye out for one at the flea markets.
  • NUTNDUN said thank you
#3 IamSherwood OFFLINE
  • 8,395 Thanks
Posted October 14, 2013 - 06:36 AM
That's too bad. Do you have a timing issue, with that backfire?
#4 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted October 14, 2013 - 07:54 AM
Had that happen in a K241 Kohler. This one was at high throttle though. The hood was off and the tractor was inside. It drove the spark plug right into the ceiling.
  • NUTNDUN and Texas Deere and Horse have said thanks
#5 NUTNDUN OFFLINE
  • 10,353 Thanks
Posted October 14, 2013 - 03:09 PM
I don't think the timing is off but I am going to check it to be sure.
I think it backfired because I didn't tune it completely yet and when it was idling for longer than just a brief moment the rpms slowly dropped until it just started to die and I went to hit the throttle to try and catch it and the extra air made it pop.
  • IamSherwood said thank you
Also tagged with one or more of these keywords: kohler, heli coil, spark plug, k341
