Clutch/transmission Problems
39 replies to this topic
#16 suburban 12 OFFLINE
suburban 12
  • 396 Thanks
  • 325 posts
Posted October 15, 2013 - 06:28 PM
My brother said there is a crank on ebay for about $100 after shipping.
#17 farmerall OFFLINE
farmerall
  • 2,207 Thanks
  • 1,475 posts
Posted October 15, 2013 - 06:33 PM
I think some of this damage may have been caused by using the tractor to move large snow banks by hitting them at a high speed. The snow blade is bent a good bit and I bet this tractor was worked hard for a long time.
Here is the one I found on ebay.
http://www.ebay.com/...=item2ecab13878
  • Texas Deere and Horse and suburban 12 have said thanks
#18 suburban 12 OFFLINE
suburban 12
  • 396 Thanks
  • 325 posts
Posted October 15, 2013 - 06:37 PM
Thanks. The model of the engine on my bush hog is TR-10D not TRA-10D. What is the difference between the two?
#19 farmerall OFFLINE
farmerall
  • 2,207 Thanks
  • 1,475 posts
Posted October 15, 2013 - 06:43 PM
I believe there only small differences such as the TRA10D has electric ignition compared to the magneto ignition on your engine and the TRA10D has slightly more hp due to a bigger cylinder bore. Other than that I think most of the parts will interchange. If it helps you at all the TRA10D is the same model engine in my 1050.
Edited by farmerall, October 15, 2013 - 06:45 PM.
  • sacsr and suburban 12 have said thanks
#20 olcowhand ONLINE
  • 42,522 Thanks
  • 31,838 posts
Posted October 15, 2013 - 06:56 PM
The TR10D is actually just 8 1/4HP where the TRA10D is a full 10HP.  Sadly, all my D4-10's have TR10D engines.
  • suburban 12 said thank you
#21 olcowhand ONLINE
  • 42,522 Thanks
  • 31,838 posts
Posted October 15, 2013 - 06:59 PM
Man, would never have guessed a broken crank!  The throwout bearing looks to be much like that used in the Power King tractors.
http://www.ebay.com/...984.m1438.l2649
#22 suburban 12 OFFLINE
suburban 12
  • 396 Thanks
  • 325 posts
Posted October 15, 2013 - 07:33 PM
Luckily, my brother hoards bolens parts and tractors and said that he would give me a TRA10D to rebuild. They appear to be the same size and mounting pattern. All I would need to do is get the crank, new rod, and other stuff to rebuild it.
  • MH81 and sacsr have said thanks
#23 MH81 OFFLINE
Posted October 15, 2013 - 10:09 PM
Wow, sorry about the crank. That had to be a weak spot somehow as so many of the GURUs hadn't ever seen it before.
Hopefully the repower isn't hard or expensive.
Is there a chance Matt had a good crank in the parts pile and you could just swap it in?
#24 Texas Deere and Horse OFFLINE
  • 14,866 Thanks
  • 15,512 posts
Posted October 15, 2013 - 10:29 PM
Matt, If you are talking about the bend in the A-Frame of the blade that attaches to the tractor, it is bent upward under the front axle if I remember correctly.
#25 suburban 12 OFFLINE
suburban 12
  • 396 Thanks
  • 325 posts
Posted October 15, 2013 - 11:40 PM
The crank in the bush hog engine is a special design, longer in the front for a front pto, and hollowed out in the back so that the drive shaft has plenty of room to extend through the clutch. That's why I cant just take an engine straight out of one of his parts tractors.
No, he is talking about the blade its self, it is bent and dented in quite a few places.
#26 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,470 Thanks
  • 3,370 posts
Posted October 16, 2013 - 06:44 AM
If you want to, put a list of parts you need, I may can help. I can get the crank, may can come up with the throw out bearing. Will try to put together a package deal.
#27 suburban 12 OFFLINE
suburban 12
  • 396 Thanks
  • 325 posts
Posted October 16, 2013 - 01:22 PM
Thanks, will see what else I might need. I need a crank (and matched rod would be great), a headlight if you have one, throw-out bearing, and a seat frame it you have one. I dont need one, but if you have one laying around, a shifter lever for the hi/lo (somehow the one on mine got bent). I dont think I will need much else, but will check.
#28 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,470 Thanks
  • 3,370 posts
Posted October 16, 2013 - 06:14 PM
Can you take a close up of the condition of your headlight?? Maybe front and back....will try to match up in condition....I have several I can choose from.
The crank is at a guys place and I will have to go get it.....I may could go by the end of the week.....will have to see how that works out. I also might have a used throw out bearing that is good. I know I have one NOS...but not sure I want to part with it.....
Will look in my boxes to see what I can come up with.
#29 Texas Deere and Horse OFFLINE
  • 14,866 Thanks
  • 15,512 posts
Posted October 16, 2013 - 06:17 PM
Scott, I'm glad you have all those parts to help BH owners out.
  • sacsr said thank you
#30 suburban 12 OFFLINE
suburban 12
  • 396 Thanks
  • 325 posts
Posted October 16, 2013 - 09:26 PM
I will take a few pics of the good light, they don't match, the broken one is a replacement. Thanks for the help.
