Foot Pedal Control On The Ff
sears ff 20 fwd/rev linkage
18 replies to this topic
#16 IamSherwood OFFLINE
  • 8,391 Thanks
Posted October 12, 2013 - 06:36 AM
This is how Toro did it on some of theirhydro rigs.
Any idea which models?
That's an interesting idea. A couple of my MFs have the "creeping hydro lever"  ailment.
I've tried several times to adjust the tension.
#17 skyrydr2 OFFLINE
  • 3,908 Thanks
  • 3,411 posts
Posted October 12, 2013 - 01:43 PM
268h is one. What they do is attach a plate to the control arm so the magnet has something to grab. Then they have a safety switch relay setup to kick it off when the brake is applied.
#18 KennyP OFFLINE
  • 39,078 Thanks
  • 46,286 posts
Posted October 12, 2013 - 06:53 PM
Here's the Ford brake parts I spoke about earlier:
Might even be able to use that to run the fwd/rev!
#19 olcowhand ONLINE
  • 41,845 Thanks
  • 31,623 posts
Posted October 12, 2013 - 06:57 PM
I've been mulling over in my head how to do my friction lock.  Maybe on the pedal shaft put a round disc, and just use brake pucks with a quick adjust so I can lessen the friction as needed between foot & hand control.  I figure it would need a lighter setting for foot control, but only way to know is to build it & try it.  Using electromagnet would work, but more to power & something else to burn out & that would of course be at the worst time.
  • SupplySergeant said thank you
Also tagged with one or more of these keywords: sears ff 20, fwd/rev linkage
