Soft Shoes----
12 replies to this topic
#1 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted October 10, 2013 - 03:26 PM
  ---- for the blower. I had some of this( I can't remember the acronym for it's name) laying around so thought I'd make new brackets to fasten it to since the originals didn't have enough slot to allow for the extra 1/2" thickness. I'll see how well they wear on bare concrete.
  • MH81, Cvans, boyscout862 and 2 others have said thanks
#2 Arti ONLINE
Arti
  • 1,366 Thanks
  • 990 posts
Posted October 10, 2013 - 04:17 PM
Nice fab job !
#3 Sawdust ONLINE
Sawdust
  • 6,049 Thanks
  • 3,502 posts
Posted October 10, 2013 - 04:21 PM
What kind of material did you use? I have noticed some of the new walkers have a pad like this instead of the rubber foot. It looks like teflon on these.
#4 KC9KAS OFFLINE
KC9KAS
  • 5,445 Thanks
  • 4,712 posts
Posted October 10, 2013 - 06:31 PM
UHMW?
…the World's Toughest Polymer, Ultra High Molecular Weight (UHMW)
#5 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted October 10, 2013 - 08:16 PM
UHMW?
  Thanks, I think that's what it is. I picked up a piece about a foot square yrs ago and have used it for a few little projects. Thought I'd give it a try. The slots on the brackets took some time. Drill a 5/16" hole on each end then cut the slots w/ the sabre saw and the file them so the bolt will slide thru easily. I just used some #10x 1/2" sheetmetal screws I had on hand to attach the UHMW.
                                                        Thanks to everyone,
        Mike
#6 MH81 OFFLINE
Posted October 10, 2013 - 09:02 PM
Very nice fab job. Really nice looking upgrade.
#7 KC9KAS OFFLINE
KC9KAS
  • 5,445 Thanks
  • 4,712 posts
Posted October 11, 2013 - 04:18 AM
UHMW is used for all kinds of things.....On table saw fence's there is much less resistance while moving the wood against it.
There is no end to what it can be used for....
It can be purchased at United States Plastics from Lima Ohio....Very good place to do business....And very quick service too. Oh, you can buy "Online".
Edited by KC9KAS, October 11, 2013 - 04:19 AM.
#8 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted October 11, 2013 - 06:27 AM
Good idea! Let us know how it works out. I'd be a little concerned that the #10 screws could break if you hit something solid with the shoe.
  • IamSherwood and ol' stonebreaker have said thanks
#9 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted October 11, 2013 - 06:40 AM
   If that happens I'll do a little countersink w/ a forsener bit and use a 1/4" slothead screw.
                                 Thanks,
                                             Mike
  • IamSherwood said thank you
#10 IamSherwood OFFLINE
  • 8,395 Thanks
Posted October 11, 2013 - 06:57 AM
I echo that concern. You might as well do it off the get go, before you loose them in the
snow. Or paint them red, so you can find them. :smilewink:
Great idea though. :thumbs:
#11 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted October 11, 2013 - 09:36 AM
  I'll let everyone know if I lose one. I want to go ahead w/ them just to see. I personally think the #10 screws are pretty tough especially since this blower isn't being pushed by a tractor w/ weights and chains, inertia from forward speed is not a big factor, but I guess time will tell.
                                                      Mike
#12 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted October 11, 2013 - 08:15 PM
                                 Thanks,
                                             Mike
I thought it was a tractor mount. Even so I think I'd go with 1/4". I'm not sure how good UHMW holds threads.
#13 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted October 11, 2013 - 08:33 PM
  I drilled a 3/32" pilot hole and it screwed in pretty hard. As I said I'll try it like this and if I lose one then I'll go the 1/4" route.
    Hey, I'm retired, I gotta have something to do in the winter, though I have projects lined up. I have a '54 Evinrude 15 HP that's going to get a new paint job in the original blue and new decals, Then the cone tranny is coming out of the Dixon. It's working fine, I just want to make sure everything is right in it. I'm also going to fab a mulching baffle for the deck from some 16 ga I have, buy a mulching blade and see if the 8 1/2 HP Honda has enough snort to mulch next spring.
                                                  Mike
