Batteries
18 replies to this topic
#1 sodisr OFFLINE
sodisr
  • 663 Thanks
  • 773 posts
Posted October 09, 2013 - 10:01 AM
Are tractor batteries  any different than car batts.  ?  I'm thinking that tractor batts. get bounced around a lot more AND would this cause the batt. to not last as long ??  Like in a tractor batt. bounceing is like agitateing or constantely sloshing the electrodes and the plates around keeping them rinsing and creating a fresh charge of electrodes
        Any thoughts
             I need a new batt for my bolens                                                  Thanks    sodisr
  • JRJ said thank you
#2 HDWildBill OFFLINE
  • 8,984 Thanks
Posted October 09, 2013 - 10:12 AM
To me when you install any battery it is a shot in the dark as to how long it will last.  My Craftsman GT had the original battery in it and it is 12 years old.  I did the Epsom salts treatment 2 years ago and as long as I don't let the tractor just sit for a couple of months it fires right up.  On the other hand I have installed batteries in other tractors and only had them last for a year or two.  Cars are the same way.  The Sportage still has the original battery where the wife's Sedona has had a total of 3 batteries and hers in a year newer.
I have read where some of the guys use car batteries in their tractors.  I also just bought a tractor that has a motorcycle battery in it.
#3 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted October 09, 2013 - 10:23 AM
The small generic lawn tractor batteries don't seem to be anything special and I don't think they are constructed any differently than a larger car battery. Both my JD GT's have small car batteries in them and there doesn't seem to be any problem. I always make sure the battery is secured so it can't move. Both the above mentioned JD tractors had the batteries loose in the tray when I got them. That is a hazard IMO as a short circuit can easily result in a fire. The batteries have a hard life as they are often installed in tractors that don't have a good regulator or in some newer tractors they don't even have a regulator, just a diode in series with the charge coil. They also get left out in the cold and unused for months at a time and loose their charge then bake inside a hot engine compartment in the summer.  I figure if you get more than 5 years out of one it's done it's duty.
  • sodisr said thank you
#4 sodisr OFFLINE
sodisr
  • 663 Thanks
  • 773 posts
Posted October 09, 2013 - 11:04 AM
what is the epsom salt treatment ???   If I may ask ??
#5 TAHOE OFFLINE
TAHOE
  • 8,310 Thanks
  • 5,804 posts
Posted October 09, 2013 - 11:25 AM
I think that's the big reason, they don't get used and go dead, then get recharged in the spring. Lettin g abattery completely go dead and sit shortens the life span. Not to mention, they have smaller amperages and if they get any loads on them, they can't handle it like a car battery would. I have noticed the batteries in the tractors I tend to use all year round last much longer. I just replaced an Autozone GT battery after 8 yrs, this tractor was mower duty in summer, snow blower in winter, it was regularly charged and used.
Shoot, I just had to replace the top of the line HD battery in the wife's Jeep Liberty after only 2 yrs, it wouldn't keep a charge. Glad I had a 3 yr full replacement!
  • HDWildBill said thank you
#6 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted October 09, 2013 - 11:51 AM
Would someone that is familiar with the Epson salt treatment of batteries please re post it for I forgot what it consisted of but I do remember seeing it once upon a time.  Thank You.
Dick
  • 14,889 Thanks
  • 15,514 posts
Posted October 09, 2013 - 12:40 PM
Here is a link to the Epson Salt treatment for battery's. I have had pretty good success with it.
http://gardentractor...lt in battery
  • HDWildBill, sodisr and TAHOE have said thanks
#8 HDWildBill OFFLINE
  • 8,984 Thanks
Posted October 09, 2013 - 01:02 PM
Thanks Brian.   :thumbs:
#9 Sawdust ONLINE
Sawdust
  • 6,154 Thanks
  • 3,549 posts
Posted October 09, 2013 - 01:25 PM
The next time I buy a battery I think I will get an ATV battery. These are more durable, cells are not as close together & most are sealed. Back when I did a lot of 4 wheeling we always used marine batteries for the same reason.
  • Texas Deere and Horse, sacsr and TAHOE have said thanks
#10 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted October 09, 2013 - 06:05 PM
I always buy the biggest battery that can fit in the battery box.  I have been told that the hardest thing on batteries is zapping all the amps available at one time trying to start a system that works best on higher amps.
Some systems are hard on batteries, that's why life expectancy on a lawn mower battery is usually one year.  They give you an el-cheapo less than adequate CCA battery that is nearly drained by the time an engine starts.  Some manufacturers design the electric clutch to work through the battery not off the charging system.
Ben W.
#11 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted October 09, 2013 - 06:33 PM
Thanks Brian that is exactly what I was looking for.
Dick
Edited by JRJ, October 09, 2013 - 06:33 PM.
#12 Sparky OFFLINE
Sparky
  • 1,298 Thanks
  • 1,892 posts
Posted October 09, 2013 - 08:15 PM
If the battery is only being charged to 3/4 or less capacity and left out in cold , sulphation could occur  in sealed batts and not be detected.  14 volts or better ok on cold weather but no more than 13.8 in hot .  Smart chargers from house current  or battery trickle chargers may be helpful in winter time .
#13 NUTNDUN OFFLINE
  • 10,353 Thanks
Posted October 09, 2013 - 08:19 PM
I just put a new battery in the HD-12. I did the epsom salt treatment on the old one and it did help but this last time the tractor was sitting without the battery it drained. Went to put it back in and when I went to push on the positive connection you could hear the post was separated from the inside of the battery. Figured it was best to just replace it.
#14 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted October 09, 2013 - 09:21 PM
  Been using the HF float chargers on my ATV and OPE batteries for 2 yrs and have had good luck w/ them.
                                           Mike
#15 HDWildBill OFFLINE
  • 8,984 Thanks
Posted October 09, 2013 - 09:53 PM
When the bike is just sitting in the shop it stays on a battery tender and so far I haven't had any issues with the battery.  I have a battery tender pig tail on the GT but I usually end up using the tender for something else.  :wallbanging:
