Jacobsen Chief/ford Transaxle Gear
rearend transaxle gear hydro
5 replies to this topic
#1 Ford100120 OFFLINE
Ford100120
  • 14 posts
Posted October 08, 2013 - 10:28 PM
I bought a 1450 Super Chief.(HYDRO  Guy I bought said when he ran it made a pop then would not go forward anymore.
Got it home it does want to go forward but it trys to grab but cant. Runs perfect in reverse. My guess is tooth or teeth are broken on forward gear.
I have the rear end seperated from the tractor. I was just wondering if anyone has split the transaxle on one of these. Can you just take set screws out of the (pumpkin) and seperate to change out the gear. I have another rear end that gears are still good in.Had bad axle splines on it .
Edited by Ford100120, October 08, 2013 - 10:29 PM.
#2 KennyP ONLINE
  • 41,445 Thanks
  • 47,379 posts
Posted October 09, 2013 - 06:05 AM
I'm trying to figure out what you are calling the pumpkin. What year is this tractor? Got a pic so we know what it is?
#3 Ford100120 OFFLINE
Ford100120
  • 14 posts
Posted October 09, 2013 - 07:29 AM
Center of the transaxle where the gears are.
#4 EricFromPa ONLINE
EricFromPa
  • 4,293 Thanks
  • 3,412 posts
Posted October 09, 2013 - 04:40 PM
Check the relief valves or Check valves on the pump.
It if moves in reverse fine then the transaxle is fine.The transaxle is just a 4 speed peerless with 1 gear instead of 4 gears.If the gears in the pumpkin or Differential were to be broken then it would not go forward or reverse.
It should have a Sundstrand 90-2029 pump on it.Which is a variation of the Sundstrand Model 15 pump.The check valves are just 2 springs and 2 small steel balls.The springs will collapse over time and if there is any water in the fliud.
Exceeded my download limit for today Downloading manuals for my Library but this should cover your pump.
http://gardentractor...del-15-service/
If replacing the springs does not help then you may have to rebuild the charge pump.
There is a way to check the pressure in the charge pump but I've never done it myself.My Ford 120 (same tranny as yours)moved in reverse fine but was struggling to go forward.I replaced the check valve springs and it worked fine.
Edited by EricFromPa, October 09, 2013 - 04:50 PM.
#5 Ford100120 OFFLINE
Ford100120
  • 14 posts
Posted October 10, 2013 - 07:49 AM
Pulled transaxle apart. Pulled out bad gear. Replaced with good one from another transaxle I had.  Thanks for the replies.
#6 KennyP ONLINE
  • 41,445 Thanks
  • 47,379 posts
Posted October 10, 2013 - 07:52 AM
I never did figure out which transaxle this one is!
