From Small To Larger Diesel.
31 replies to this topic
#1 Cvans OFFLINE
  • 7,056 Thanks
  • 6,282 posts
Posted October 08, 2013 - 09:15 PM
Have a couple of diesel projects this winter so I thought I better get started.
Several years ago I purchased a Kubota G4200 garden tractor. It's a 2 cyl. 12hp. (Z430) diesel of 430cc displacement. I've had a Kubota snow blower for this series of tractor and gave it a try last winter. The little 12hp. engine is definitely short of ponies for this large blower.
I was able to locate a 3 cyl. Kubota (D950) 950cc, 21.5hp. diesel engine for very reasonable so the snow blower is going to have plenty of power this winter. As you can see in the following photo there is a big difference in the size of these two engines which is going to necessitate lengthening the frame 6 inches.
The first thing needing change was the belt pulley adapter that bolts to the flywheel. It needed to have the shoulder machined off of the face, the outside diameter reduced, and new mounting holes drilled and taped into the flywheel and pulley adapter.
Next some material had to be removed from the engines back plate so the engine could set down into the frame rails.
Then the flywheel was replaced along with the pulley adapter. Fortunately the drive shaft adapter on the front of both engines used the same bolt pattern so nothing needed to be done there.
And here is going to be the new home for the D950.
  • olcowhand, Alc, KennyP and 6 others have said thanks
#2 olcowhand OFFLINE
  • 42,287 Thanks
  • 31,764 posts
Posted October 08, 2013 - 09:17 PM
Woohoo....love this project!
  • Cvans said thank you
#3 bowtiebutler956 OFFLINE
bowtiebutler956
  • 660 Thanks
  • 796 posts
Posted October 08, 2013 - 09:26 PM
 This is going to be good! Love it! :thumbs:
Matt
#4 Talntedmrgreen ONLINE
  • 3,279 Thanks
  • 2,311 posts
Posted October 09, 2013 - 05:21 AM
Cool!
#5 KennyP ONLINE
  • 40,005 Thanks
  • 46,718 posts
Posted October 09, 2013 - 07:06 AM
That should perk it up. I take it you haven't extended the frame as yet?
#6 Cvans OFFLINE
  • 7,056 Thanks
  • 6,282 posts
Posted October 09, 2013 - 09:15 AM
Not yet. This gets worked on between fishing trips this time of year. I've had the engine hanging in the frame to get measurements.
Fortunately I have another tractor like this for parts will use it for the frame parts I need to extend this one. Hopefully tomorrow I will extend it and then drop the engine in. Today it's off to the lake.  :thumbs:
Edited by Cvans, October 09, 2013 - 09:16 AM.
#7 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted October 09, 2013 - 10:37 AM
That should make the snow fly. Does the larger engine rev as high as the 2 cylinder one. You may have to change pulley sizes to maintain the same blower speed.
#8 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted October 09, 2013 - 11:05 AM
Chris youll love the power of the 950. They run very well and are easy to get a few extra ponies out of just in case its needed. What tractor is this going into?
#9 Cvans OFFLINE
  • 7,056 Thanks
  • 6,282 posts
Posted October 09, 2013 - 11:24 AM
Kubota G4200.
#10 Cvans OFFLINE
  • 7,056 Thanks
  • 6,282 posts
Posted October 09, 2013 - 11:26 AM
Rpm's should be fine.
Thinking about speeding the blower up a little to throw the snow farther.   :smilewink:
#11 Cvans OFFLINE
  • 7,056 Thanks
  • 6,282 posts
Posted October 10, 2013 - 09:28 PM
This afternoon I was able to spend a few hours working on the frame. I had forgotten that I had installed a Lister-Petters into
 the frame at one time. So after removing the modifications both frames were cut and welded back together.
This is where the project stands as of this evening.
  • olcowhand, Texas Deere and Horse, wvbuzzmaster and 2 others have said thanks
#12 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted October 10, 2013 - 10:44 PM
Looks like you are making good progress.
#13 Trav1s OFFLINE
Trav1s
  • 3,509 Thanks
  • 4,491 posts
Posted October 14, 2013 - 10:22 PM
That 12 would be perfect for a 140  :smilewink:
#14 Texas Deere and Horse OFFLINE
  • 14,862 Thanks
  • 15,511 posts
Posted October 14, 2013 - 11:58 PM
Chris, you are getting there, I think it will handle the faster running SB with ho problems. :thumbs:
#15 Cvans OFFLINE
  • 7,056 Thanks
  • 6,282 posts
Posted October 15, 2013 - 12:26 AM
Here are some photos of where I left off on Saturday evening. I came in at 10:30 tonight and was too tired to start taking photos and down loading them. Will get some more tomorrow.
The engine was mounted, PTO spacer made, and drive shaft installed.
Hope to have it running and moving under it's own power tomorrow.
  • olcowhand, wvbuzzmaster and twostep have said thanks
