More Hp Out Of An 10 Kohler?
11 replies to this topic
#1 Swinny OFFLINE
Swinny
  • 6 Thanks
  • 9 posts
Posted October 08, 2013 - 08:30 PM
I just bought a cub 1000 with a 10 HP kohler. I was looking for tricks and tips to get the most power out of that engine. What about plaining the head,bigger cam,carb just looking for ideas.
  • A.C.T. said thank you
#2 A.C.T. OFFLINE
A.C.T.
    Another Classic Tractor
  • 2,364 Thanks
  • 2,496 posts
Posted October 09, 2013 - 12:32 AM
#3 KC9KAS OFFLINE
KC9KAS
  • 5,443 Thanks
  • 4,710 posts
Posted October 09, 2013 - 04:14 AM
I know guys that spend thousands of dollars to increase HP for their GT pullers.
#4 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted October 09, 2013 - 06:24 AM
Brian Miller is the man to talk to.
http://gardentractor...s.com/index.htm
Ben W.
#5 baerpath OFFLINE
baerpath
  • 314 Thanks
  • 514 posts
Posted October 09, 2013 - 07:22 AM
Valve job, cam,swap head to either a heart head or a LP head, bore .30 over new piston and rings  just clean and rebuild the carb
Kinda depends on what your rules say you can do
  • Sawdust said thank you
#6 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted October 09, 2013 - 10:53 AM
Are you building it into a puller? If so you'll need to upgrade your driveline and a few components of your rear end as well to handle it all. I know baerpath runs with a 10hp I believe and he can tell you how they run. In my honest opinion I wouldn't mess with a 10. Id go to a 14 or 16 if your going to go crazy with it but you might have around 7-8000$ in when your done.
#7 Swinny OFFLINE
Swinny
  • 6 Thanks
  • 9 posts
Posted October 09, 2013 - 12:07 PM
Can you put a cam, valves,carbs from a bigger HP kohler into a 10 if so how big?
#8 baerpath OFFLINE
baerpath
  • 314 Thanks
  • 514 posts
Posted October 09, 2013 - 02:17 PM
Check your rules and see what you can do.    \     Check your rules and see what you can do.
Some like running a 18hp K361 cam for better lugging if your required to stay with OEM parts thats one I;d do. If you can run the same lift but longer duration check with Vogel's or another reputable cam grinder.   A stock engine that runs great won't do sqat if you can't get the hp to the track.
Turn it into a puller 1st and get it to hook up then go for a better engine.   Clutch, rear end, tires, and weight system are just as if not more important  than a hot motor
  • Dieselcubmike said thank you
#9 EricFromPa OFFLINE
EricFromPa
  • 3,961 Thanks
  • 3,235 posts
Posted October 09, 2013 - 05:20 PM
K361 cams are getting very hard to come by and they usually sell for more than a Fully adjustable 2 piece Vogel cam.
Toss a fresh #30 carb on it and upgrade the ignition to either a solid state ignition or crank trigger and a LP head.Depending on the block you have it could be bored out and a 12hp piston could be used in it.Would have to see the casting numbers on the block though to confirm that it's either a 12hp block with 10hp bore or a standard 10hp block.
That's about all I would do with a 10/12hp block.
If you upgrade to a 14 0r 16hp block with a little work done to it you will have to put a good bit of money into the driveline to keep from blowing diffs,axles,driveshafts,clutches and gears apart every time you hook to the sled.
I used to Dead weight pull locally with a CC102 with a 12hp K301 block,It had an LP head,#30 carter,ring gear mini starter,shaved flywheel veins and a stock clutch with red spring.Did not have much money into it and pulled pretty good for a stock class tractor with an open Diff.
Go get a rule book from your local club and go over it and decide what class you want to run in then build your puller.
Edited by EricFromPa, October 09, 2013 - 05:23 PM.
#10 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,849 Thanks
  • 10,036 posts
Posted October 09, 2013 - 05:41 PM
Look up Kirk Engines Killer Kohler K241 project.
http://www.kirkengines.com/
#11 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,849 Thanks
  • 10,036 posts
Posted October 09, 2013 - 05:42 PM
Ummmh. . . .  at what point does trueing up the head become milling the head???
#12 Swinny OFFLINE
Swinny
  • 6 Thanks
  • 9 posts
Posted October 10, 2013 - 08:00 AM
Where would you find the casting numbers on the block?
