Kubota G4200 Z430 2Cyl Diesel
hard to start
20 replies to this topic
#16 8tyman8 OFFLINE
8tyman8
  • 415 Thanks
  • 731 posts
Posted October 07, 2013 - 10:01 PM
My Z482 in my bolens is becoming more dependent on 2 battery's When it is cold Under 15 Degrees Celcius in the morning and I am thinking of upgrading the starter to a Gear reduction version
  • Cvans, JRJ and gunnoyl have said thanks
#17 Cvans ONLINE
  • 7,089 Thanks
  • 6,297 posts
Posted October 07, 2013 - 11:08 PM
Check to make sure both glow plugs are working. It'll start with one but it's a lot harder.
  • JRJ and gunnoyl have said thanks
#18 gunnoyl OFFLINE
gunnoyl
  • 12 Thanks
  • 9 posts
Posted October 10, 2013 - 04:52 PM
Learning more on the G4200 everyday...lol. I know about the dash indicator, however, I have a friend that has a diesel shop and he says to visually verify that the glow plugs are heating up inside the head, because the dash element may be weak or not working. I removed the injectors and I could see the plugs glowing bright as Christmas lights. I also manipulated the fuel plumbing as to hook the injectors outside of the head to see the spray patterns, and #1 looked different than #2. I now have them at said friend's shop so he can "pop" test them. Kubota says 1990-2150 psi. One thing at a time (or after another). After explaining symptoms, and everything I have done thus far, he says it sounds like an injector problem. So now waiting to hear back from him, and preparing myself to purchase a set of injectors.
  • JRJ said thank you
#19 olcowhand ONLINE
  • 42,427 Thanks
  • 31,811 posts
Posted October 10, 2013 - 04:57 PM
If the glow plugs aren't working or barely working, then the indicator will not glow bright red, as too little or no current will be drawn.  The injectors can cause a lot of issues, so you're on the right path there.
#20 braxx OFFLINE
braxx
  • 20 Thanks
  • 45 posts
Posted October 10, 2013 - 06:12 PM
I don't have anything new to add except that I have had 2 diesel compact tractors. One only required 30-40 seconds of glow plug warming to start in any thing below 50deg. My other one REQUIRED at least 60 seconds at 35ish to 50deg. Below freezing and it required a good 90 seconds of glow plug heating.
Sent from my S3 now Free
#21 cumminsmannow OFFLINE
cumminsmannow
  • 100 Thanks
  • 294 posts
Posted October 30, 2013 - 02:50 PM
Gear reduction starter will make it spin over super fast and start it so easily. You have to get one off of a bigger motor like a d1105
  • Cvans and JRJ have said thanks
