My New Massey 1650
110 replies to this topic
#91 BairleaFarm OFFLINE
BairleaFarm
  • 1366 Thanks
  • 1788 posts
Posted February 02, 2014 - 08:45 PM
I'm still having a hard time with the carbs lol. These are the two carbs I have and the two kits. The kohler kit is just the seat the other has welch plugs.
uploadfromtaptalk1391391914672.jpg uploadfromtaptalk1391391925072.jpg uploadfromtaptalk1391391935127.jpg
#92 BairleaFarm OFFLINE
BairleaFarm
  • 1366 Thanks
  • 1788 posts
Posted February 02, 2014 - 08:46 PM
The crank seal fell out now I'm working on the petrified pan gasket.
#93 olcowhand OFFLINE
  • 44102 Thanks
  • 32301 posts
Posted February 02, 2014 - 09:25 PM
I like spray gasket remover.  Even the most rock hard gaskets come right off after using it, or at least after 2 applications.
  • Texas Deere and Horse and BairleaFarm have said thanks
#94 BairleaFarm OFFLINE
BairleaFarm
  • 1366 Thanks
  • 1788 posts
Posted March 01, 2014 - 07:56 PM
I got a new job so I've been busy with life. I finally got out to the shop. Got the oil a pan gasket and seal replaced. Hopefully I can get her running tomorrow. We're getting close to plow time and spring clean up.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
#95 TAHOE OFFLINE
TAHOE
  • 8514 Thanks
  • 5931 posts
Posted March 01, 2014 - 08:11 PM
Was wondering if you wer still alive.
Good to hear you've been getting shop time, I am so eager to get otu there, but still in the middle of this bathroom remodel.....and probably plowing snow again Monday.
  • BairleaFarm said thank you
#96 BairleaFarm OFFLINE
BairleaFarm
  • 1366 Thanks
  • 1788 posts
Posted March 01, 2014 - 09:03 PM
She runs. I need to get a air filter. What size are the air filter housing to carb screws? I knocked the air filter housing over and my shop ate the screws.
#97 Gabriel OFFLINE
Gabriel
  • 1454 Thanks
  • 1868 posts
Posted March 01, 2014 - 10:05 PM
I'm glad you got it running!
#98 BairleaFarm OFFLINE
BairleaFarm
  • 1366 Thanks
  • 1788 posts
Posted March 15, 2014 - 04:04 PM
The carb ids worse now than before the rebuild. I needed to plow so I threw a 10hp carb acc adjusted it. The tractor runs good and im happy with it. This was the first time I really got to work it. This one may be a keeper.uploadfromtaptalk1394917479839.jpg
  • twostep and Gabriel have said thanks
#99 BairleaFarm OFFLINE
BairleaFarm
  • 1366 Thanks
  • 1788 posts
Posted March 15, 2014 - 04:56 PM
While disking the go pedal quit working.
I'm thinking about getting rid of the carrier bearing and doing a full drive shaft with ujoints.
  • twostep said thank you
#100 coldone OFFLINE
coldone
  • 1716 Thanks
  • 1709 posts
Posted March 15, 2014 - 08:09 PM
You just cant seem to win with this one. I know the feeling, have a 1650 been sitting in my shop for 3 years. Stick with it and it will be worth it. One thing I have thought about is contacting eaton to get a replacement input shaft for the hydro. The eaton 11 was used in several different GTs and had several different input shafts. I know mine will go out sometime so I have been thinking of solutions.
#101 olcowhand OFFLINE
  • 44102 Thanks
  • 32301 posts
Posted March 15, 2014 - 08:17 PM
David, being you'd like to go to a universal joint hydro shaft, maybe you could remove the hydro input shaft, have it turned down to fit a universal yoke, then have a keyway cut into it.  You'd be fine from then on.
#102 BairleaFarm OFFLINE
BairleaFarm
  • 1366 Thanks
  • 1788 posts
Posted March 16, 2014 - 07:44 AM
I don't know how I want to go. I would assume I have to pull the pump apart to get that shaft out. Not something I want to do.
Sent from my SAMSUNG-SGH-I437P using Tapatalk
#103 olcowhand OFFLINE
  • 44102 Thanks
  • 32301 posts
Posted March 16, 2014 - 07:57 AM
The MTD 990 tractor used the same pump, but DID have the woodruff keyed smooth shaft.  Maybe you can locate a used pump.
#104 BairleaFarm OFFLINE
BairleaFarm
  • 1366 Thanks
  • 1788 posts
Posted March 16, 2014 - 11:17 AM
I'd still have to pull the pump apart. I don't know yet I'm getting tired of this thing.
#105 TAHOE OFFLINE
TAHOE
  • 8514 Thanks
  • 5931 posts
Posted March 16, 2014 - 06:43 PM
Obviously that input shaft is toast as is other than milling down and re-surfacing as Daniel said.
I've heard guys drilling and bolting shaft and coupler together, but that would be last resort for me.
