My New Massey 1650
110 replies to this topic
#61 olcowhand OFFLINE
  • 44107 Thanks
  • 32302 posts
Posted October 24, 2013 - 08:02 PM
I hate this rear lights. Every time I walk in the shop I want to kick them out. They will be changed next week. Today when I used it the rod under the seat didn't move. I'm sure that's why the rear pto doesn't work. I haven't investigated any further.
Belts are either missing, or been lifted off pulleys & tied out of the way.
#62 BairleaFarm OFFLINE
BairleaFarm
  • 1366 Thanks
  • 1788 posts
Posted October 27, 2013 - 02:57 PM
Since this engine is such crap I can't really use it. I did some looking under it just get an idea of what I may or may not need to this this mechanically great by the spring. I was looking to see if the belts were off the pulley. Turns out there are no pulleys. In a perfect world twostep forgot to give me the pulleys but I'll assume he never had them lol.
#63 olcowhand OFFLINE
  • 44107 Thanks
  • 32302 posts
Posted October 27, 2013 - 03:00 PM
No, Bobby never had them.  Easy to tell they've been taken off a long time.
#64 twostep OFFLINE
twostep
    Rockstar
  • 2003 Thanks
  • 2544 posts
Posted October 27, 2013 - 03:21 PM
Dang man, that sucks. I never looked under it either. I now there are belts (and I assume pulleys) on back end. Why would someone take those off???
#65 TAHOE OFFLINE
TAHOE
  • 8514 Thanks
  • 5931 posts
Posted October 27, 2013 - 07:21 PM
My 1855 was the same way, lever and lower pulley were there, no upper pulley or driveshaft ....I dunno!
#66 BairleaFarm OFFLINE
BairleaFarm
  • 1366 Thanks
  • 1788 posts
Posted October 27, 2013 - 07:48 PM
All the backside pulleys are there. I think. It looks like there was some driveshaft work done and at the time the pulleys weren't installed. I wonder if I can play with pulley size and get this down to a 540 pto? Or at least get it close?
#67 olcowhand OFFLINE
  • 44107 Thanks
  • 32302 posts
Posted October 27, 2013 - 07:55 PM
No room to change pulley sizes back at the rear, and little room to change ratio much in the front.  You "might get it down to 1500rpm if you were lucky.
#68 bigge61 OFFLINE
bigge61
  • 100 Thanks
  • 59 posts
Posted December 15, 2013 - 08:30 PM
My 1450 is also missing the pulley on the pto shaft at the front and no pulley on the driveshaft going from the motor to the hydro! While the back of the tractor is complete with pulleys and belts! I just assumed that previous owner put new driveshaft in and didn't get the right one...  I was just going to put two matching pulleys on some way and hope for the best!  Gonna have to wait till I either get one of my1655's going or buy this 1855 I am working on to tear it apart though.  Can't be without a tractor it might snow and then i would have to shovel!
  • BairleaFarm said thank you
#69 BairleaFarm OFFLINE
BairleaFarm
  • 1366 Thanks
  • 1788 posts
Posted December 19, 2013 - 06:08 PM
Money is non existent due to work cutbacks. I had a guy call who lives a few miles down the road. He wants to trade me a 16hp from a jd216 for the snapper. Motor runs fine but a crank seal is leaking a little. The Massey may be running next week. Woohoo
Sent from my Desire HD using Tapatalk 2
  • olcowhand, MH81 and twostep have said thanks
#70 olcowhand OFFLINE
  • 44107 Thanks
  • 32302 posts
Posted December 19, 2013 - 06:14 PM
Wondering lately where you've been!  Which crank seal...flywheel or stub side?
#71 BairleaFarm OFFLINE
BairleaFarm
  • 1366 Thanks
  • 1788 posts
Posted December 19, 2013 - 06:23 PM
Sounded like PTO side on the phone. I'm keeping my fingers crossed. I'm going tomorrow after work to hear it run before he pulls it.
#72 olcowhand OFFLINE
  • 44107 Thanks
  • 32302 posts
Posted December 19, 2013 - 06:35 PM
That'll be easy as sin to pull the seal & replace.
#73 BairleaFarm OFFLINE
BairleaFarm
  • 1366 Thanks
  • 1788 posts
Posted December 20, 2013 - 08:12 PM
It will be a few days before I get the engine so I changed something that has been bothering me. I bit the bullet and drilled new mounting holes. Bigger than stock but not horrible.
#74 twostep OFFLINE
twostep
    Rockstar
  • 2003 Thanks
  • 2544 posts
Posted December 20, 2013 - 10:16 PM
Those look much better.
#75 BairleaFarm OFFLINE
BairleaFarm
  • 1366 Thanks
  • 1788 posts
Posted December 21, 2013 - 03:57 PM
I drained the hydro fluid. It was horribly dirty. Looked to be hytrans or so. Is there a easier way to fill than this straw sized fill tube?
