Why Does It Run Now?
21 replies to this topic
#1 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted October 06, 2013 - 02:34 PM
That's right, the stupid thing runs again.... I only took the flywheel off and did nothing to it. Let it sit until I needed the space, and put it back together... Tuned the key and it started right up like nothing happened..... So what now???
  • Dieselcubmike and JRJ have said thanks
#2 shorty ONLINE
shorty
  • 5,836 Thanks
  • 5,417 posts
Posted October 06, 2013 - 02:38 PM
Finally decided to stop bugging you, so that he can go to the next plow day. :D
  • wvbuzzmaster said thank you
#3 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted October 06, 2013 - 02:40 PM
There is one up around Columbus later this month lol.
  • shorty said thank you
#4 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 14,126 Thanks
  • 10,198 posts
Posted October 06, 2013 - 04:34 PM
I told you the flywheel nut was too tight, but oh no! You wouldn't listen to me. :thumbs:
#5 IamSherwood OFFLINE
  • 8,395 Thanks
Posted October 06, 2013 - 05:04 PM
Well what the heck???
That's almost worse than not knowing why it doesn't run!!!
#6 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted October 06, 2013 - 06:03 PM
Exactly my disgust with it.... Why do you think I get so aggrivted with it....
#7 MH81 OFFLINE
  • 29,979 Thanks
Posted October 06, 2013 - 07:02 PM
Geez, it's almost like its your sister or something...
#8 EricFromPa ONLINE
EricFromPa
  • 4,184 Thanks
  • 3,356 posts
Posted October 06, 2013 - 07:06 PM
Is that the Briggs Twin?
Might be a bad ground on the coil or the kill wire may be shorting somewhere.
  • wvbuzzmaster and farmerall have said thanks
#9 bread320i OFFLINE
bread320i
  • 613 Thanks
  • 1,225 posts
Posted October 06, 2013 - 07:12 PM
Time to sell while it runs...
#10 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted October 06, 2013 - 07:15 PM
yes it is the Briggs twin.
Right, thought about that but it was making spark so it wold mean it was not grounded out.
#11 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted October 06, 2013 - 07:21 PM
Possibly in the ignition switch and you moved or bumped a wire and now it is making contact.
Dick
#12 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted October 06, 2013 - 07:28 PM
The problem will probably be back Casey! Intermittent faults can be a real pain!
#13 DougT OFFLINE
DougT
    Dog Approved
  • 7,116 Thanks
  • 5,079 posts
Posted October 06, 2013 - 07:31 PM
Casey, its a real complicated formula involving the alignment of the moon and the stars and such. Take note of the conditions so you know when you can rely on it. Always park it facing north.
PS:  I'd also vote with the guys that are saying bad connection or grounded wire. How about a kinked fuel line??
#14 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted October 06, 2013 - 07:45 PM
I have thought of everything, but everything is new around the engine lol. The ignition switch is 2 years old, fuel line was redone this year. Wiring was redone 2 years ago. I mean man, there is nothing wrong except it's temper I guess...
Edited by wvbuzzmaster, October 06, 2013 - 07:46 PM.
#15 MH81 OFFLINE
  • 29,979 Thanks
Posted October 06, 2013 - 07:54 PM
Did you ever grind off the fuel shutoff in the bottom of the carb?
