Long Lt280D ?
4 replies to this topic
#1 KennyP ONLINE
  • 52537 Thanks
  • 53102 posts
Posted October 06, 2013 - 05:47 AM
Has anyone ever taken the front drive shaft out of one of these? A friend is having an issue with his and can't figure out how it comes apart.
#2 skyrydr2 OFFLINE
  • 3919 Thanks
  • 3413 posts
Posted October 07, 2013 - 03:54 AM
 Is it a 4 wd farm tractor ?  is the driveshaft in a "tube" going  down the belly? If so You will need to remove the axle assembly at the osilation point (front axle mount) These front axles can be a WICKED BOOGER to get apart too , good luck and BE SAFE !!
#3 KennyP ONLINE
  • 52537 Thanks
  • 53102 posts
Posted October 07, 2013 - 05:14 AM
Yes, 4WD. And yes to the tube. Had a feeling that was what needed to happen. It's Aaron's Dad's tractor. Thanks!
#4 KennyP ONLINE
  • 52537 Thanks
  • 53102 posts
Posted October 23, 2013 - 06:53 PM
Update!!! He got the drive shaft apart. It has splined couplings on each end and one had split apart. The cause for that is some bolts for the front axle had worked loose, let it bind! Thus breaking the coupling!
#5 BTS OFFLINE
BTS
    Make Stuff Up
  • 4864 Thanks
  • 2709 posts
Posted October 27, 2013 - 08:43 AM
Great, glad he got it fixed up!
