1970 E15
130 replies to this topic
#106 DH1 ONLINE
DH1
    Electric Tractors
  • 5,415 Thanks
  • 5,616 posts
Posted April 27, 2016 - 02:26 PM
Today I worked on it again, got the lights finally mounted and the charger, I bought a ProMariner charger a while back, "ProSport20Plus" decided to put it in with the Alltrax.
All that is left to do is install the red reflector and seat cushion's which I need to get made up, aside from that it's FINISHED.
Problems I had
1 - the hole in the battery box that the wires go through was a little small, I would make that hole about 1" longer to make it easier to feed the wires through especially if you use larger or double them up as I did.
2 - the fuse block I had was n/g, there is the part that holds the fuse and the part that the wire screws to, they are held together with a rivet that was a little loose and caused intermittent connection for both the controller and electric lift, I put in a new one.
3 - the seat switch I bought for it was the late model type, I installed it, sat on the tractor and broke it into pieces, the late mode tractors have a cutout in the wooden piece that is under the seat cover, mine doesn't have that cutout as it is the early model type which the switch mounts to the outside of the battery box. I put the early switch back on it.
4 - I don't have a key for this tractor so I used a toggle switch.
5 - paint I tried to skimp and ended up painting it 2x, next time I do it right the first time.
6 - spray on bedliner lifted the paint and made a bit of a mess, next time roll on bed liner.
How I did the potbox or throttle for the controller.
I bought a foot throttle and mounted it on the underside of the foot rest and had the pedal come through to the top side.
Controller needs a reverse switch so you can go backwards, I used the reverse switch that is in the original hand control, works good, like a shuttle shift.
Pictures
  • Mr Electrak, wvbuzzmaster, IamSherwood and 7 others have said thanks
#107 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted April 27, 2016 - 02:46 PM
Looks great Doug.
  • DH1 said thank you
#108 CRFarnsworth OFFLINE
CRFarnsworth
  • 5,177 Thanks
  • 2,255 posts
Posted April 27, 2016 - 03:27 PM
Looks great Doug.
Yep.  What he said!      Rick
#109 KennyP ONLINE
  • 40,918 Thanks
  • 47,117 posts
Posted April 27, 2016 - 05:21 PM
Great job on it Doug! I'd be proud to own it!
#110 IamSherwood OFFLINE
  • 8,395 Thanks
Posted April 27, 2016 - 07:30 PM
Looks really darn good Doug, I'd love to own it.
 but it seems like you're really deep
in thought about the project.
If you're not happy with it, start over!
#111 DH1 ONLINE
DH1
    Electric Tractors
  • 5,415 Thanks
  • 5,616 posts
Posted April 27, 2016 - 07:45 PM
I am happy with the way it turned out, I got 4 more to work on, I look at it as a leaning experience, and the next one will be easier to do.
This one is really nice to drive, and it goes to French Creek plowday may 7th. It can pull a 10" Brinly plow through the dirt in top (4th gear) with the power use meter in the green zone.
Edited by DH1, April 27, 2016 - 07:45 PM.
  • Mr Electrak, wvbuzzmaster, IamSherwood and 3 others have said thanks
#112 CRFarnsworth OFFLINE
CRFarnsworth
  • 5,177 Thanks
  • 2,255 posts
Posted April 28, 2016 - 09:36 PM
If you need more practice , you could convert mine over to the newer electric controls.  :D      Rick   ​
  • DH1, KennyP and sacsr have said thanks
#113 DH1 ONLINE
DH1
    Electric Tractors
  • 5,415 Thanks
  • 5,616 posts
Posted May 08, 2016 - 02:24 PM
I took E15 with a 10" Brinly plow down to a Plowday event in PA, wanted to see what it could do. Saw some old friends and met some new ones, the weather nice and the fields good for plowing.
I ran the tractor at least 2hr maybe 3hrs total and at least 1hr pulling the plow. Found that when in L or 2nd gear tractor has lots of power but moves a little slow, in D1 or 3rd gear it still has lots of power and moves a bit faster power use meter in the middle of the green, in D2 or 4th gear it can pull the plow, speed is faster, power use meter is at the top of the green and it feels like it's struggling, D1 or 3rd seems to be the best gear to use.
Traction was not a problem I had Carlisle All Trails on with NO extra weight added.
After I got home I checked the batteries to see how much charge was left and they were at about 50%.
I am really happy with the way it performed these GE tractors can do it and looking forward to going to another Plowday. Thanks to Alan MH81 for the pictures.
  • Mr Electrak, wvbuzzmaster, KennyP and 4 others have said thanks
#114 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted May 08, 2016 - 02:39 PM
I was surprised about the All Trails having enough traction with only the weight of the batteries, but it did very well.
Edited by wvbuzzmaster, May 08, 2016 - 02:40 PM.
  • DH1 and Traill95 have said thanks
#115 KennyP ONLINE
  • 40,918 Thanks
  • 47,117 posts
Posted May 08, 2016 - 03:47 PM
Good to hear it performed well, Doug! Bet that is one quiet tractor to plow with!
Casey, he had plenty of weight with those batteries!
#116 Traill95 ONLINE
Traill95
    Traill95
  • 1,858 Thanks
  • 1,020 posts
Posted May 08, 2016 - 04:41 PM
attachicon.gifpost-802-0-99401300-1456681070.jpgattachicon.gifgallery_802_898_167418.jpg
So How much difference is there between my E14 and your E15? Shouldn't the E14 be able to pull the plow also? I need to find a plow and hitch first I guess. :D
Edited by Traill95, May 08, 2016 - 04:41 PM.
  • DH1 and Mr Electrak have said thanks
#117 DH1 ONLINE
DH1
    Electric Tractors
  • 5,415 Thanks
  • 5,616 posts
Posted May 08, 2016 - 04:49 PM
I think they all can pull the plow, bigger motor tractors would be faster.
  • CRFarnsworth and Traill95 have said thanks
#118 Canawler ONLINE
Canawler
  • 1,951 Thanks
  • 1,806 posts
Posted May 09, 2016 - 02:15 PM
That's good to hear about the All-Trails. Was that the pair I sold you at Dover a couple years ago?
#119 DH1 ONLINE
DH1
    Electric Tractors
  • 5,415 Thanks
  • 5,616 posts
Posted May 09, 2016 - 05:38 PM
Yes sir it was, I like those tires and going to get me some more.
#120 Canawler ONLINE
Canawler
  • 1,951 Thanks
  • 1,806 posts
Posted May 09, 2016 - 06:41 PM
I'm a fan of those as well. The other two from that set are on my Meteor and I have two of the 10.50s on my GTX-18.
