My Latest Project...
23 replies to this topic
#1 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted October 05, 2013 - 08:29 AM
is this 1450 Cub Cadet. Goingto repaint it and it needs some mechanical work also. The battery discharges like crazy when the key is turned on. I think something is hooked up wrong. The engine needs some new gaskets,also. This is goingto be my snowplowing tractor for this winter, so I hope to get it done within the next month. I have a blade for it and I am goingto repaint it, also.Will keep everybody updated on the progress.
  • daytime dave, CRFarnsworth, HDWildBill and 2 others have said thanks
#2 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,807 Thanks
  • 4,302 posts
Posted October 05, 2013 - 10:09 AM
Thanx, Levi! We are excited to hear  and see the projekt progressing :thumbs:
  • LTD said thank you
#3 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted October 05, 2013 - 10:11 AM
It looks like a good foundation to start with.
Sent from my SCH-I535 using Tapatalk 4
#4 Sawdust OFFLINE
Sawdust
  • 6,152 Thanks
  • 3,547 posts
Posted October 05, 2013 - 10:19 AM
Looking forward to your project...a nice one. I have a 1250 I want to do when I finish my MF12.
#5 HDWildBill OFFLINE
  • 8,984 Thanks
Posted October 05, 2013 - 11:09 AM
I agree it looks like you have a good starting point.  Looking forward to seeing the progress with it.
#6 powerstroker00 OFFLINE
powerstroker00
  • 669 Thanks
  • 332 posts
Posted October 05, 2013 - 03:48 PM
we have a 1650 that was discharging like that. it turned out to be the ignition switch, replaced it and it works fine now.
#7 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted October 05, 2013 - 04:23 PM
Well, I got it most of the way torn down this afternoon. Didn't really run into anything thay looks like it will be a major problem. Hardest part was getting the steering wheel off(as usual). I decided to take the flywheel off to check the stator. Glad I did;there was a mouse nest right next to the cooling fins. The stator looks fine, don't think that's why it discharging. I am goingto wash the engine. Will it hurt the stator if it gets some water on it?
Hood and grill off.
Fender pan off.
PTO switch was rusted solid. I have another one for it though.
I think a lot of the oil leakage is the coming from the crankcase breather.
Hour meter is in pretty good shape. It was working. Show's 260 hours, but its probably been around once or twice.
Getting ready to pull the engine.
Engine's out.
This was the worst ISO mount. They were all pretty bad though.
Mount's were so bad it wore a hole through the flywheel shroud.
Mouse nest right next to the cylinder.
Stator looks okay.
Edited by LTD, October 05, 2013 - 04:24 PM.
  • JRJ and Sawdust have said thanks
#8 daytime dave OFFLINE
  • 4,963 Thanks
  • 6,596 posts
Posted October 05, 2013 - 04:25 PM
Good luck Levi.  It looks like you got a lot of work done already.  Plenty left ahead too.
#9 Sawdust OFFLINE
Sawdust
  • 6,152 Thanks
  • 3,547 posts
Posted October 05, 2013 - 04:46 PM
Wow! that's a lot of progress for one day...I have had to stop & eat at least twice already. Looks like it's working out for you with no major problems. I just picked my 1250 up a few months ago at a steal. The PO said it ran fine then he couldn't get to start no more. At the price I got it for I didn't care. I found out the governor rod was broke so I'll be pulling the engine soon. Keep us posted.
#10 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted October 05, 2013 - 05:40 PM
They are a pain to do. Had it happen on a K301. Ended up tearing it all the way down to the governor gear,and managed to manuever it around the governor gear into place.Good luck with it.
  • Sawdust said thank you
#11 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted October 09, 2013 - 05:57 PM
Made some progress. Picked up some Iron Gard the other day. Already had the primer. I pressurewashed and sanded the rough spots on the frame. Wire-wheeled the fender pan. The top I took down to bare metal,but the bottom I just took off the rust and loose paint. Primer came out pretty smooth. Not looking for perfect on this one anyway. Goingto be a worker.
Two quarts of white and one of yellow.
Loaded up to go get pressure washed
Ready to paint
Primed
Came out pretty smooth.
Fender pan.
Edited by LTD, October 09, 2013 - 05:59 PM.
#12 TAHOE ONLINE
TAHOE
  • 8,296 Thanks
  • 5,797 posts
Posted October 10, 2013 - 08:33 AM
It could, but since you have flywheel off, you can blow it off with some air and let it sit for a few days to dry. Figuring it may be a little time before you get it back together and running, it should be plenty dried out.
Here's a pic of my Sears, it got wet and I ran it not knowing, burnt it up pretty good.
photobucket-1005-1380326940971_zpsbb4d57
#13 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted October 11, 2013 - 06:00 PM
Painted the yellow yesterday and today. Had just a little leftover for touching up.I also went and ordered new Carlisle Tru Power bar tires for the rear.Should be in Monday.
  • twostep said thank you
#14 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted October 12, 2013 - 08:24 AM
Did you paint it in the leaves? It's looking great so far.
Edited by BairleaFarm, October 12, 2013 - 08:24 AM.
#15 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted October 15, 2013 - 06:44 PM
Yep. Most of the leaves were off the trees, so there weren't any falling on the paint.Rather paint outside than in.
