Jd Mower Deck Help Needed
425 dimensions
5 replies to this topic
#1 Cat385B OFFLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,002 posts
Posted October 04, 2013 - 08:44 AM
I am looking for the physical dimensions of the 60" deck used on the 425-455 tractors. Length, width, and height. A pic of the mower deck gearbox area with the shields removed would be helpful also if the dimensions are small enough to convert one for use to my Bolens.
#2 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted October 04, 2013 - 09:00 AM
CAT, have you had a look on JDParts.com for diagrams of the decks. That would give you a general idea ofthe configuration and if it's likely to fit. The decks are listed under attachments when you look up the tractor by model no.
#3 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,771 Thanks
  • 4,263 posts
Posted October 04, 2013 - 01:04 PM
Sorry, Brian, but you'll find no dimensions in jdpc. Cat, tomorrow I'll look for an OM, but also w/out dimensions...
Edited by jd.rasentrac, October 04, 2013 - 01:04 PM.
#4 bhts OFFLINE
bhts
  • 1,472 Thanks
  • 2,165 posts
Posted October 04, 2013 - 01:54 PM
Length is 63 inches front to back is 30 inches and height is 7 to 8 inches. It should fit under there as the wheel base are close to each other. One thing to remember is the gearbox input shaft comes out the back and you need one out the front.
  • Cat385B said thank you
#5 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted October 04, 2013 - 04:04 PM
I didn't mean to go there and look for dimensions. I meant that he could look at the way the drive system and lift attachment points are arranged and get some idea how much work it would be to adapt.
  • jd.rasentrac said thank you
#6 Cat385B OFFLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,002 posts
Posted October 04, 2013 - 04:30 PM
The 30" front to back is going to be a problem. I think. The G152 only has 26" tire to tire at 7" off the floor. I would of re-used the gearbox off the Bolens deck.
Thanks for the info.
Also tagged with one or more of these keywords: 425, dimensions
