Cub 124 Reassembly .
cub cadet cub cadet 124 restoration powdercoating
75 replies to this topic
#61 JoeMopar OFFLINE
JoeMopar
  • 470 Thanks
  • 288 posts
Posted February 02, 2014 - 04:05 PM
Here's a starter group on Facebook : https://www.facebook...ctorCollectors/
Joined, thanks Mike.
#62 mike912e OFFLINE
mike912e
  • 427 Thanks
  • 241 posts
Posted February 06, 2014 - 08:19 PM
An update on the latest progress on the 124's engine re-assembly and the restoration of the headlight assembly . I've been continuing to attach sheet-metal covers to the Kohler 12HP engine . The rebuilt carb and linkage is installed as well as the PTO and front pulley . In the next day or so I will remove the hood from the Cub in preparation for the engine install .
I purchased the complete headlight assembly with taillight . All of the pieces have been cleaned , primed and painted . I first wire-brushed everything after washing all the dirt off in hot soapy water . One headlight bulb was cracked so it was replaced . All external and internal threads were chased ( ran a tap through the holes and a die over the studs ) . I spent a little extra time buffing the head of the headlight switch . I also found that scratches could be removed from the taillight lens with 3600, then 4500 grit wet or dry paper . It came out almost looking like new .
  • MH81 and Sawdust have said thanks
#63 JoeMopar OFFLINE
JoeMopar
  • 470 Thanks
  • 288 posts
Posted February 06, 2014 - 09:50 PM
Looking good as usual Mike. I bought a head light set up for my 1200 a couple of weeks ago. Installed them and one of the beams was burnt out. I was looking on line and E-Bay for a replacement beam, prices all over the place, 15-20 $$ on E-Bay for used ones. Went to the local parts store today to see if the had some. No problem $ 6.75 out the door, think I'm going to go buy a few more for the up coming tractors and to have a spare.
  • mike912e said thank you
#64 mike912e OFFLINE
mike912e
  • 427 Thanks
  • 241 posts
Posted February 06, 2014 - 09:55 PM
I know what you mean . The new taillight had both bulbs burnt out . Checked Ace and Autozone . No luck . A local small parts store had them for less than $2 each so I bought the whole box . I have also purchased 12volt tractor headlight bulbs at the local Habitat for Humanity store . A buck apiece ! They only had two but the price was right and I finally used the last one here . It sure pays to shop around .
  • Sawdust and JoeMopar have said thanks
#65 IHCubGuy OFFLINE
IHCubGuy
  • 1,500 Thanks
  • 1,579 posts
Posted February 07, 2014 - 09:38 PM
Looks good Mike. Question . Were all Cub engines suppose to be yellow ? Just certain models, years, or engines ? Curious because the motor in my 1200 is black, so is that correct or a replacement engine ?
All the Cubs up to the Quietline series had engines painted yellow.  The quietlines and 82 series had engines in them that were painted flat black.  If you had a black engine in a Cub that is older than a quietline it is a replacement engine.
From what I know, the older Cubs, mostly narrow frames were all yellow except for the black floor rests , the white hood and the silver grill screen . I purchased a brochure for the 72 to 105 Cubs and they all appear to be painted yellow after they were completely assembled ( except for the hood , footrests , grill ) . The pictures on the brochure show the engine and wiring all painted yellow , making it tough to trace out wires since they were all yellow ! I would guess that when they were bought out by MTD the engine color changed to all black . The later wide frames are not my area of expertise, yet . Were all the K series engine painted yellow ? I'll ask that question to one of the F/B groups I belong to and see what answer we get . To be continued..............
Mike, looking EXCELLENT as usual!  On the grill of these they were actually not painted silver but were an anodized finish the same as the bolts.  I know you didnt say painted but I just wanted to throw that in there for anyone that might not know.
By the way I like the Porsche.  NICE!!  Wonder what the boys from Top Gear U.K. would think about that?  LOL!!!!!!!
Edited by IHCubGuy, February 07, 2014 - 09:40 PM.
  • mike912e and JoeMopar have said thanks
#66 mike912e OFFLINE
mike912e
  • 427 Thanks
  • 241 posts
Posted February 08, 2014 - 02:36 AM
Finally have the engine in the frame . Now it's time to add all the heat shields, fuel tank mount , etc .  Ordered two new PTO wear buttons, one for the 124 and another for the 104 for next fall's restoration . I'm also gathering a bunch of pieces to haul up to the powder coater to get ahead on the 104 . Nice to have parts done and ready for assembly sitting on the shelf . The new Stens muffler is on order, along with the clamp, as the entire original unit was so rusty that it couldn't be saved . After the lesson learned on the taillight refinish, I think I'll try to restore the steering wheel rather than replace it .
I still have about three week's more work to go before she will be ready to start for the first time .
  • MH81 and JoeMopar have said thanks
#67 MH81 OFFLINE
Posted February 08, 2014 - 06:03 AM
Wow, a whole lot of pretty in this thread. I'm talking tractor pics BTW. :D
Just getting caught back up on this, Thanks for sharing your restoration(s). They look great
#68 mike912e OFFLINE
mike912e
  • 427 Thanks
  • 241 posts
Posted February 15, 2014 - 06:02 PM
Update of progress on the 124 : The engine is permanently installed along with the PTO and associated linkage . The clutch was pre-assembled before the engine was installed and will only need final adjustment . The fuel tank was a real bear to get a suitable paint finish but thanks to elbow grease and 3200 then 4500 wet/dry paper it turned out fine . One picture shows the upper bearing I was able to install in the top of the steering column . I also installed the fasteners that attach the grill casting to the frame . Lots more to do . The steering wheel needs to be restored/replaced along with a new center cap and logo . I also need to order a new fuel bowl and replace the rubber tubing that was installed between the fuel bowl and carb with copper tubing . She's finally getting there ! I'll be dropping both the 124 and 104's Kohler engine tags off at the silk screener to have the numbers engraved on the new, blank tags I made .
  • CRFarnsworth and Sawdust have said thanks
#69 Gabriel OFFLINE
Gabriel
  • 1,442 Thanks
  • 1,859 posts
Posted February 15, 2014 - 09:32 PM
Nice restoration!!!
#70 mike912e OFFLINE
mike912e
  • 427 Thanks
  • 241 posts
Posted March 14, 2014 - 03:28 PM
Things move slowly when it's cold in the garage ! Here's an update to the progress so far : Purchased and installed the two new rear fender reflectors and brackets . For reproduction pieces they are quite good . Also added the new air-cleaner decal . Retrieved the Kohler engine tag from the engraver , polished the four small push clips and installed the tag on the engine shroud ( I'll post a close-up of the tag installed if anyone wants to see it ) . Installed the new muffler clamp . I still have to restore the steering wheel or purchase a better one . The engine needs oil and the coil to point wire assembly is in and needs to be installed . Then I hope I'll be able to get her running without any hiccups ! Show time is fast approaching and I can't wait to show her off .
  • CRFarnsworth, JoeMopar and Gabriel have said thanks
#71 JoeMopar OFFLINE
JoeMopar
  • 470 Thanks
  • 288 posts
Posted March 14, 2014 - 03:38 PM
Really nice job.
#72 JDBrian ONLINE
  • 9,606 Thanks
  • 14,142 posts
Posted March 14, 2014 - 04:06 PM
That looks super. I am really liking that tractor and I think I'll look for a CC for my next project.
#73 mike912e OFFLINE
mike912e
  • 427 Thanks
  • 241 posts
Posted March 14, 2014 - 04:32 PM
Here's some closeup pics of the latest parts I installed on the 124 : The decal and reflectors are aftermarket items and I made my own reproduction Kohler engine tag .
  • Gabriel said thank you
#74 Gabriel OFFLINE
Gabriel
  • 1,442 Thanks
  • 1,859 posts
Posted March 15, 2014 - 09:29 AM
Very nice restoration!!
#75 Cublover OFFLINE
Cublover
  • 93 Thanks
  • 112 posts
Posted March 15, 2014 - 10:22 AM
Great job! That 124 came out beautiful, thanks to your attention to detail. Thanks for saving another old GT.
Also tagged with one or more of these keywords: cub cadet, cub cadet 124 restoration, powdercoating
