8Hp Briggs Case Cracked
4 replies to this topic
#1 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted October 02, 2013 - 07:37 PM
well my speedex has been leaking oil so i though it was crank seal nope long story short i found a little crack jb welded it it worked good till i split a flywheel key and it fired backwards so it torqued the starter and made 2 chunks i was looking into a re power but my uncle says he up for the challenge of welding it only problem i only have like 6 weeks till my plow days have a look
  • boyscout862 and JRJ have said thanks
#2 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted October 02, 2013 - 07:45 PM
If your uncle is any kind of a welder with a mig unit he should be able to weld in with no problem. You could help him out a little by cleaning some of the paint from the crack area, saw clean it back about  1". It should not take him to long to weld it.
Good Luck with the project.
Dick
  • superspeedex said thank you
#3 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted October 02, 2013 - 07:49 PM
Yea hes pretty good and i was going to put the new style 8 hp ohv in it for 230 but he said he could do this for much of nothing so i tore i down tonight and one of these days i ll take it over but i was amazed how nice the cylinder looked on it and i think i am going to cut the eyebrows  port and polish the intakes some and regrind the vales to hopefully gain a little bit of power
#4 olcowhand OFFLINE
  • 40,365 Thanks
  • 31,175 posts
Posted October 02, 2013 - 07:51 PM
Yes, aluminum welding requires ABSOLUTE cleanliness.  Every bit of JB Weld and paint MUST be removed in the weld area & a little way beyond as JRJ said.
#5 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted October 02, 2013 - 07:56 PM
Yea i do need to prep it and clean it with gorilla cleaner
