Case/Ingersoll
11 replies to this topic
#1 Dale OFFLINE
Dale
  • 1 posts
Posted December 07, 2010 - 10:38 AM
I have a 16hp case/ingersoll and I don't believe the governer is working because when I try to blow snow or use the tiller or even have a wagon with a load it will bog down and stall if I push it. You cannot hear the governer kick in at all. I don't know a whole lot about small engine's and someone told me this problem is most likly inside the engine. Any thoughts out there?
#2 Bolens 1000 ONLINE
  • 13,627 Thanks
  • 17,571 posts
Posted December 07, 2010 - 10:43 AM
Welcome to the Forum, Dale
Your problem could be a few different things...
Governor is a possibility...
Another thing that possibly could be wrong is your carburetor may be not adjusted right causing the engine to lack power.
I'm going to move your thread over to the case/Ingersoll forum.
#3 Bolens 1000 ONLINE
  • 13,627 Thanks
  • 17,571 posts
Posted December 07, 2010 - 10:48 AM
What kind of engine is in it?
#4 NUTNDUN OFFLINE
  • 10,289 Thanks
Posted December 07, 2010 - 01:14 PM
Could be something as simple as a spring attached to the governor the wrong way. I found this was the case with my Cub Cadet 147 when I first got it. Would help if we knew what engine you have. Welcome to GTtalk.
#5 Boss 448 OFFLINE
Boss 448
  • 48 Thanks
  • 248 posts
Posted December 21, 2010 - 09:13 AM
Does the engine just fail to rev up to meet load demand or is it popping, missing or backfiring? If it is doing any of the latter then your problem may be something else. If it is just failing to meet the load demand then I think you are correct that the governor is not responding correctly.
JN
#6 olcowhand ONLINE
  • 37,225 Thanks
  • 30,213 posts
Posted December 21, 2010 - 10:04 AM
Should be an Onan engine. While running, if you open the throttle by pushing or tugging directly on the governor arm (do this carefully to avoid over revving), and you get no resistance, then the governor is screwed up. You should feel a definite opposite force when moving it to faster rpm position. If it's the governor, it's a pretty good size job to repair.
#7 olcowhand ONLINE
  • 37,225 Thanks
  • 30,213 posts
Posted December 21, 2010 - 10:05 AM
Where are my manners! Welcome Dale & Boss448. Hope we can get your Case diagnosed properly Dale.
Edited by olcowhand, December 21, 2010 - 12:10 PM.
#8 mjodrey OFFLINE
Posted December 21, 2010 - 11:04 AM
Dale:welcometogttalk:glad to have you with us.
#9 mjodrey OFFLINE
Posted December 21, 2010 - 11:05 AM
Welcome Boss 448.
#10 MH81 ONLINE
  • 28,896 Thanks
  • 29,270 posts
Posted December 21, 2010 - 09:05 PM
Yes :welcome: Dale & Boss 448. Here's hoping it's a disconnected spring or wrongly "plumbed" assembly.
Edited by MH81, December 22, 2010 - 08:21 AM.
#11 mastifflawyer OFFLINE
mastifflawyer
  • 43 Thanks
  • 162 posts
Posted December 22, 2010 - 06:53 AM
Knock-Knock...GT Talk to Dale...Are you out there Dale? It is going on 3 weeks since you posted your request for help. There were several suggestions and questions posed. All of them good. In order for us to fix your problem you have to play along here. The problem you describe could be caused by a number of things. It is important to narrow it down by eliminating possible causes. Answer some questions. We will have it fixed in no time.
#12 caseguy OFFLINE
Posted December 22, 2010 - 07:23 AM
:wave: Welcome to GTTalk Dale (a little late) and Boss448! We're glad to have you!
