#2 Ff Is Getting An Engine
69 replies to this topic
#31 TAHOE ONLINE
TAHOE
  • 7,975 Thanks
  • 5,675 posts
Posted October 02, 2013 - 08:12 PM
Yea, many times on the fuel pumps, they can be taken apart, cleaned, then soak the rubber diaphragms in oil for a bit. It causes rubber to swell and rejuvenates it.
Glad you are headed back down the road.
#32 KennyP ONLINE
  • 38,322 Thanks
  • 45,912 posts
Posted October 03, 2013 - 04:53 AM
On both of these Onan's, they have the vacuum port off the back. Both had the tiny hole blocked with dirt. I'm hoping the one on the P220 works good. I'll find out today.
  • Alc and TAHOE have said thanks
#33 Cat385B ONLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,002 posts
Posted October 03, 2013 - 05:16 AM
Fire it now, go for 'Neighbor of the Week'.
#34 KennyP ONLINE
  • 38,322 Thanks
  • 45,912 posts
Posted October 03, 2013 - 05:36 AM
I got that yesterday morning. I beat that base plate into submission, welded it up, then ground the welds down.
  • Texas Deere and Horse and SupplySergeant have said thanks
#35 SupplySergeant ONLINE
SupplySergeant
    Eggman's Dad
  • 1,815 Thanks
  • 1,008 posts
Posted October 03, 2013 - 01:51 PM
At 4 AM, too, I bet!  :watch_over_fence: Back behind my fence now, neighbor!
#36 HowardsMF155 OFFLINE
  • 2,861 Thanks
  • 2,987 posts
Posted October 03, 2013 - 02:44 PM
Doggone, Kenny must be working HARD on this.  No posts here since 6:30 am!!
Com'on man, give us an update!!
  • KennyP and SupplySergeant have said thanks
#37 KennyP ONLINE
  • 38,322 Thanks
  • 45,912 posts
Posted October 03, 2013 - 05:15 PM
I finally got it running, guys. But I am unsure about the hdyro. Neutral is not where it is supposed to be! Wonder if someone got in there and swapped some things around.. Neutral is up into the forward travel area. I adjusted all I know about & can't get it back where it belongs. Gotta be something in this mess! May have to take both fender pans off and compare.
#38 Texas Deere and Horse OFFLINE
  • 14,811 Thanks
  • 15,499 posts
Posted October 03, 2013 - 05:31 PM
At least you have a couple extra 2 speed hydro's laying around if you need them. :D
#39 KennyP ONLINE
  • 38,322 Thanks
  • 45,912 posts
Posted October 03, 2013 - 05:39 PM
I am low on hydro knowledge! I can adjust it to where it moves good, but neutral is still way out!
#40 skyrydr2 OFFLINE
  • 3,886 Thanks
  • 3,410 posts
Posted October 04, 2013 - 03:13 AM
It could have lost the key on the shaft going into the hydro. Its a tapered stub so you could tighten it down to work. Check this out first and see , especially if the nut is loose . You can't mess things up inside the unit with out really really trying .
It could have something bent or a shaft twisted because the parking brake was set and they forced the lever to move???
  • MH81, KennyP and twostep have said thanks
#41 KennyP ONLINE
  • 38,322 Thanks
  • 45,912 posts
Posted October 04, 2013 - 04:22 AM
Thanks, Keith. I'll look into all that.
Here's where I stand with it this morning. Got to get the neutral where it belongs. The new axle seal I put in a while back is leaking profusely. And I have to get exhaust figured out. There is no room for the muffler that was on it without modifications. And the exhaust hasn't been removed from the engine, mounting bolts to ports are rusted badly. I won't try to loosen them until I warm the engine up.
But it runs and moves. That's a start.
Edited by KennyP, October 04, 2013 - 07:28 AM.
  • Texas Deere and Horse and IamSherwood have said thanks
#42 KennyP ONLINE
  • 38,322 Thanks
  • 45,912 posts
Posted October 04, 2013 - 04:48 PM
Well, the neutral issue was none of the above. There is a concentric bolt the linkage pivots on that was out  of adjustment. Look for the red dot in the pic.
Got the exhaust under control, used the original muffler. I cut the outlet off the bottom, capped that. Then I drilled a new hole in the side where I wanted and applied a little weld.
It is still very quiet.
  • olcowhand, MH81, IamSherwood and 3 others have said thanks
#43 Texas Deere and Horse OFFLINE
  • 14,811 Thanks
  • 15,499 posts
Posted October 04, 2013 - 06:00 PM
Good deal Kenny, where's the video?
#44 KennyP ONLINE
  • 38,322 Thanks
  • 45,912 posts
Posted October 04, 2013 - 06:19 PM
Got to work on the video taking, Brian! Got other things on my mind and not on learning new phone skills!
#45 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted October 04, 2013 - 10:34 PM
Good job there Kenny. Looks like you will have that thing ready for winter snow removal.
Edited by wvbuzzmaster, October 04, 2013 - 10:34 PM.
