Glowing Muffler? And Missing Battery Cover Help.
26 replies to this topic
#1 pwombles OFFLINE
pwombles
  • 201 Thanks
  • 220 posts
Posted September 30, 2013 - 08:56 PM
So I have a 1976 Montgomery Ward Transaxle 8 that I have been working on. I have cleaned the head, replaced the crankcase breather, Rebuilt carb, Cleaned valve faces to shiny, replaced spark plug, and replaced the mufflerDSCF5540.JPG DSCF5543.JPG . When it runs at full throttle, it doesnt take long for the muffler to start glowing. I dont feel that this is normal and was wondering what might be the cause of it. I ran some seafoam in it in the beginning and was wondering if that might be the cause. I also run high octane gas in all my equipment and was wondering if that might cause that too? Also wondering if anyone has a battery cover that goes on this as mine is missing. as seen in last pic.DSCF5536.JPG
Edited by pwombles, September 30, 2013 - 08:58 PM.
  • Texas Deere and Horse, boyscout862, A.C.T. and 1 other said thanks
  • 14,730 Thanks
  • 15,470 posts
Posted September 30, 2013 - 09:00 PM
I can tell that I used to light my cigarettes off of our Gas powered farm tractors, and their mufflers glow red all the time when working them. Lawn/garden tractors burn up every year from combustibles catching fire in the engine area.
  • boyscout862 and JRJ have said thanks
#3 MH81 OFFLINE
Posted September 30, 2013 - 09:05 PM
Sometimes a tractor that is running lean will run hotter. Maybe open up the main jet a quarter turn and see?
  • Utah Smitty and JRJ have said thanks
#4 Utah Smitty OFFLINE
Utah Smitty
  • 1,701 Thanks
  • 1,781 posts
Posted September 30, 2013 - 09:20 PM
I can tell that I used to light my cigarettes off of our Gas powered farm tractors, and their mufflers glow red all the time when working them. Lawn/garden burn up every year from combustibles catching fire in the engine area.
My BMW R65's exhaust pipes would glow red clear to the muffler as well.
Smitty
#5 SupplySergeant ONLINE
SupplySergeant
    Eggman's Dad
  • 1,717 Thanks
  • 969 posts
Posted September 30, 2013 - 09:51 PM
These things do run hot. However, if the timing is advancd too far, it will heat up a muffler far faster than normal. I didn't see timing mentioned in your post, have you checked it? When I first got my JD140, I accidentally set the timing about 15 degrees too advanced, and I could have welded that muffler with itself!
Edited by SupplySergeant, September 30, 2013 - 10:20 PM.
#6 HowardsMF155 OFFLINE
  • 2,836 Thanks
  • 2,977 posts
Posted September 30, 2013 - 09:59 PM
Ditto on the timing.  I had a Tecumseh that was turning the muffler red.  Sounded like it was running good too, but lacked power.  Finally tracked it down to an ignition timing issue.
  • Alc and JRJ have said thanks
#7 pwombles OFFLINE
pwombles
  • 201 Thanks
  • 220 posts
Posted September 30, 2013 - 10:20 PM
i actually did nothing to the "timing" as it fired off when I cranked it. I believe it might have a magnetron, but I dont know for sure. Should I check flywheel key, points and condenser, if so equipped!  I did put an E3 plug in it.But it glowed when it had the old plug too. there is just not much to check on a briggs when It comes to timing. Someone please explain
#8 SupplySergeant ONLINE
SupplySergeant
    Eggman's Dad
  • 1,717 Thanks
  • 969 posts
Posted September 30, 2013 - 10:23 PM
I don't really now anything about this tractor, is it battery ignition or magneto?
#9 pwombles OFFLINE
pwombles
  • 201 Thanks
  • 220 posts
Posted September 30, 2013 - 10:41 PM
it has a mag, but has the smaller starter bolted to the side of the engine with an alternator under the flywheel
#190707
#10 SupplySergeant ONLINE
SupplySergeant
    Eggman's Dad
  • 1,717 Thanks
  • 969 posts
Posted September 30, 2013 - 11:37 PM
If it's mag-fired, then usually the only way for timing to be off is a sheared flywheel key. The gap between the flywheel and mag is part of it, but you usually can't screw that up too much and still have the engine fire.
#11 A.C.T. OFFLINE
A.C.T.
    Another Classic Tractor
  • 2,364 Thanks
  • 2,496 posts
Posted September 30, 2013 - 11:53 PM
imagesCA1YXKJ0.jpg I will jump on.....I agree timing related.
#12 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted October 01, 2013 - 05:21 AM
I used to have one of those cheapo jd l140s and was mowing one night and and on both cylinders the pipe was glowing.  But as far as glowing pipes my kawi 450 with titanium header pipe hill glow read clear to the muffler
#13 JDBrian OFFLINE
  • 9,601 Thanks
Posted October 01, 2013 - 05:30 AM
Try adjusting the high speed jet 1/4 turn richer and see if it changes anything. Too lean maybe?
#14 SupplySergeant ONLINE
SupplySergeant
    Eggman's Dad
  • 1,717 Thanks
  • 969 posts
Posted October 01, 2013 - 01:10 PM
Was it a repower? 140's have 1-cylinder Kohlers.
#15 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted October 01, 2013 - 02:03 PM
The lowes l130
