Sold
Bolens 1254 Driveshaft
8 replies to this topic
#1 EricFromPa ONLINE
EricFromPa
  • 3,669 Thanks
  • 3,118 posts
Posted September 30, 2013 - 04:10 PM
I'm in need of a Complete driveshaft assembly for a Gear Drive 6 speed Tube Frame Bolens.Must have the Dual drive belt set up like the 1050.
Here's a pic of what I need.
I am not working so it must be pretty Cheap.
The bearings on my driveshaft are shot.The front bearing is cracked and the rear bearing is dry and worn out.
Thank you very very much.
Eric
  • JRJ said thank you
#2 boyscout862 OFFLINE
  • 12,864 Thanks
  • 9,175 posts
Posted October 01, 2013 - 07:40 AM
You can just replace the bearings. I've been looking for a driveshaft for my 853 for years. They are either very expensive or worn out too. Good Luck. Rick
#3 EricFromPa ONLINE
EricFromPa
  • 3,669 Thanks
  • 3,118 posts
Posted October 01, 2013 - 08:16 AM
Priced new bearings part # 1185587 $51.71 for the front and # 1704479 is $139.98 for the rear bearing.That's the cheapest that I can find.
#4 EricFromPa ONLINE
EricFromPa
  • 3,669 Thanks
  • 3,118 posts
Posted October 01, 2013 - 11:17 PM
Anyone have a driveshaft? Or bearings cheap?
#5 EricFromPa ONLINE
EricFromPa
  • 3,669 Thanks
  • 3,118 posts
Posted October 10, 2013 - 02:30 PM
I'm Still looking for either a whole driveshaft assembly or just the Bearings.If Anyone has a parts tractor laying around Please let me know what your wanting for the parts that I need.
Thank you very much.
Eric
#6 Bruce Dorsi ONLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,915 Thanks
  • 2,451 posts
Posted October 11, 2013 - 06:45 AM
Those two bearings are available from a bearing supply house much cheaper than those prices quoted as Bolens parts.   ....You want to remove the bearings from their holders, and purchase just the bearings.
If you remove the bearings, they should have industry-standard numbers on them.  .....Failing that, measure them accurately, or take them to a supply house and they can identify them.
The front bearing (and I think the rear bearing) are known as self-aligning bearings.  ....These are commonly used in pillow-block bearing assys, but they can be purchased separately, without the housing.  .....These bearings have a wide inner race.
While you are at it, now may be a good time to replace the two needle bearings in the lower pulley, as well. ....They should be approx $6-$8 each (need two).
Edited by Bruce Dorsi, October 11, 2013 - 06:47 AM.
  • EricFromPa, sacsr and boyscout862 have said thanks
#7 EricFromPa ONLINE
EricFromPa
  • 3,669 Thanks
  • 3,118 posts
Posted October 11, 2013 - 04:42 PM
I have the bearings out and measured them.The rear bearing is Metric 30mm x 62mm x 16mm.Forgot where I wrote the dimensions for the front bearing down but The rear bearing is just a standard Flanged Metric ball bearing.Found them for $18.95 and ordered 2.So I have a spare.
http://bearingsdirec...0x62x16-24.html
My Pulley Needle bearings are in really good condition surprisingly.They still have grease and spin very very well but I'll look those up as well.
#8 EricFromPa ONLINE
EricFromPa
  • 3,669 Thanks
  • 3,118 posts
Posted October 15, 2013 - 02:15 AM
I managed to get bearings off of someone.
Can someone close this wanted Ad please.I can't remember how to do it lol.
#9 KennyP OFFLINE
  • 38,418 Thanks
  • 45,945 posts
Posted October 15, 2013 - 06:14 AM
I marked it as Sold for ya. We don't have a Found label!
Also tagged with one or more of these keywords: Sold
