Parts In The Mail And I Have A Question.
7 replies to this topic
#1 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted September 30, 2013 - 04:08 PM
I was browsing random Facebook pages and can't across a guy parting out a 10hp. No pictures no nothing I bought some stuff sight unseen. 65$ got me the carb, starter, regulator, and air cleaner shipped to my door.
The regulator is way smaller than the ones I have and the pins are oriented different. It will still work with my stators correct?
Will this air cleaner fit all kohler carbs?
Sent from my SCH-I535 using Tapatalk 4
  • JRJ said thank you
#2 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted September 30, 2013 - 04:09 PM
#3 JDBrian OFFLINE
  • 9,610 Thanks
  • 14,144 posts
Posted September 30, 2013 - 04:22 PM
Looks like the standard size regulator that is on the K321 and KT17 that I have in JD tractors. Have a look in the Kohler engine manual to verify the wiring before you connect it. That looks like the standard oblong Kohler air cleaner canister and should fit the 12-16hp motors for sure. I'm not sure about the smaller ones.
  • 14,730 Thanks
  • 15,470 posts
Those are K series parts off of a 200 or 300Kohler JD model. Most all the Regulators do the same job.
#5 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted September 30, 2013 - 05:07 PM
The manual? Duh why didn't I think about that
Thanks
  • MH81 and Texas Deere and Horse have said thanks
#6 ckjakline OFFLINE
ckjakline
  • 1,139 Thanks
  • 1,129 posts
Posted September 30, 2013 - 08:03 PM
That particular air cleaner was used on the quite line model kohlers.cub cadet ,john deere,massey ferguson.Mainly the tractors where the engine are covered on the side.
  • BairleaFarm said thank you
#7 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted September 30, 2013 - 08:49 PM
I noticed it will fit the engine I'm putting in my cub. I'm excited knowing it was ment to be.
#8 TAHOE OFFLINE
TAHOE
  • 7,814 Thanks
  • 5,612 posts
Posted October 01, 2013 - 08:22 AM
I've come to learn just about any of the later style regulators, like you pictured, will work with any system using the AC/B+/AC system. Since getting my sears, I have ran three different Sears types, a kohler, and I am now running one from an Onan. I finally broke down and bought a brand new one ( onan) as I was just using old used ones I had lying around. As long as the regulator matches your charging output and you get wiring correct, they will work. I burnt up the Kohler one as it was only rated at 15 amps, my system is a 20 amp plus I was using winch, it didn't last too long. I now have my 20amp Tecumseh feeding through a 20 amp Onan regulator, hopefully this new one will finally hold up.
10 Hp kohler carb...I want!!!! :smilewink:
