Make Your Own Lock Nuts
22 replies to this topic
#16 John@Reliable OFFLINE
John@Reliable
  • 1,298 Thanks
  • 1,416 posts
Posted September 30, 2013 - 05:44 PM
Hmmm....sounds a little strange us speaking of smashing our nuts with a hammer!  :rolling:
:(               :bigrofl:
#17 UncleWillie OFFLINE
  • 15,535 Thanks
  • 8,710 posts
Posted September 30, 2013 - 06:23 PM
Ow ow ow ow.
#18 daytime dave OFFLINE
  • 4,785 Thanks
  • 6,523 posts
Posted September 30, 2013 - 07:54 PM
And putting them in a vise and applying force.  (Although I had a similar experience during divorce from the ex's atty.)
I'm glad I was not alone in thinking these thoughts as I read this post.
  • olcowhand and Alc have said thanks
#19 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted October 01, 2013 - 05:37 PM
I have always used a center punch on the flats or if threads are exposed stake the threads.
Staking the threads was the procedure we used in the factory along with red lock tight when assembling hammer mill cylinders at Farmhand. That job took a 160 lb man on a 6 ft wrench to torque the nuts, Building and balancing cylinders was an education.
#20 UncleWillie OFFLINE
  • 15,535 Thanks
  • 8,710 posts
Posted October 01, 2013 - 06:41 PM
If you didn't weigh 160 did the calibrate the length of the bar?????
#21 smokestack76 OFFLINE
smokestack76
  • 83 Thanks
  • 86 posts
Posted October 01, 2013 - 06:52 PM
OK read this whole thread. Still don't get it :wub: How do i make one :huh: Beat a lock washer onto the nut? In sure its easy for most but i am lost :o
Sent from my SAMSUNG-SGH-I717 using Tapatalk 2
#22 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted October 01, 2013 - 07:04 PM
Good question! Since I only weighed 145 at the time I would jump on the bar several times. The engineer said that would do it.
#23 freedhardwoods OFFLINE
freedhardwoods
  • 374 Thanks
  • 197 posts
Posted October 20, 2013 - 06:42 PM
I forgot about this thread till I just found it.
In the first picture in my original post you would just squeeze the nut on one side until it isn't round anymore. You start the round side of the nut on a bolt, and the friction of the oblong side holds it on.
  • smokestack76 said thank you
