Expensive Friday Evening Mowing Session
24 replies to this topic
#16 KennyP ONLINE
  • 38,417 Thanks
  • 45,945 posts
Posted September 29, 2013 - 05:14 PM
The Jacobsen is still not completely diagnosed, but I'm thinking the input shaft of the Eaton is supposed to spin, not have a 1" wobble to it. It has an inch side to side, up and down, all over the place play, but won't spin either direction.
Something went to poo-poo inside there! Never had one apart, not even taken one loose from the axle. If you did replace the Eaton, I imagine a good flushing of the axle would be a necessity.
#17 IamSherwood OFFLINE
  • 8,391 Thanks
Posted September 29, 2013 - 05:49 PM
Tough one Scott. I hope you can find a replacement
Eaton, so that 72" deck gets back to work.
#18 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,322 Thanks
  • 9,788 posts
Posted September 29, 2013 - 05:58 PM
It sounds like pure neglect. I think you need a job that keeps you home more. :poke:
#19 Cat385B ONLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,004 posts
Posted September 29, 2013 - 07:49 PM
It hasn't been started for about six weeks prior to this. Very dry around here.
#20 dodge trucker ONLINE
dodge trucker
  • 2,441 Thanks
  • 3,131 posts
Posted October 03, 2013 - 09:18 PM
I have (2) Eaton 11s under the bench collecting dust; I didn't pull them so IDK what they came from; I got them because I thought they were Eaton 7s.. they are bigger.    One has a tag on it that is old and unreadable I think its either new or factory rebuilt... the other is just a used one I know nothing about.. no cracks or gaping holes in the case!
#21 Cat385B ONLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,004 posts
Posted October 04, 2013 - 06:54 AM
I am still unsure what the exact model number is. Isn't there like 5 variations of the Eaton 11?
#22 KennyP ONLINE
  • 38,417 Thanks
  • 45,945 posts
Posted October 05, 2013 - 06:33 AM
Where's skyrydr2 when ya need him? He seems to know these pretty good.
#23 Cat385B ONLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,004 posts
Posted October 05, 2013 - 06:10 PM
The Bolens steering column is back on and working as it should. New bearing at the bottom of the shaft, and some custom grinding to get it to fit. Re-assembled, had the teeth off by one. (it only turned halfway to the left) After getting it right and bolted in a second time, I realized I forgot to add the gear oil. :mad2:  And the fill plug is under the fuel tank. Take it off again! There is a whole bunch of new scratches on the dash paint job now. :rolling:
#24 olcowhand ONLINE
  • 41,205 Thanks
  • 31,435 posts
Posted October 05, 2013 - 06:14 PM
Cat scratches no doubt!!   :bigrofl:
  • KennyP and NJKen have said thanks
#25 KennyP ONLINE
  • 38,417 Thanks
  • 45,945 posts
Posted October 05, 2013 - 07:02 PM
:bigrofl: :bigrofl: :bigrofl:
