Beefing Up Rear End
4 replies to this topic
#1 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted September 29, 2013 - 08:20 AM
I have broken 2 of these carryers. It takes out ring gear then when it snaps it breaks the bearing mount off. so I came up with a backing plate with that carrys a bigger bearing. It also puts more metal on back of ring gear for more support.2013-09-26113911_zpsdd945708.jpg2013-09-26113454_zps5e7bb2fc.jpg2013-09-24214640_zps2e6eb455.jpg2013-09-20133402_zpsd27cafc7.jpg
Edited by Chris11, September 29, 2013 - 08:15 PM.
  • boyscout862 and JRJ have said thanks
#2 boyscout862 OFFLINE
  • 13,693 Thanks
  • 9,476 posts
Posted September 29, 2013 - 08:32 AM
Nice machine. What is the carrier from? What are you using it for that breaks it? Sure is nice to have the tools and knowledge. Good Luck, Rick
#3 KC9KAS OFFLINE
KC9KAS
  • 5,482 Thanks
  • 4,736 posts
Posted September 29, 2013 - 09:08 AM
Nice fab work.....Shouldn't have that problem again!
#4 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted September 29, 2013 - 09:24 AM
It is nice to have the know how and tools to do this kind of work.
Dick
#5 Chris11 OFFLINE
Chris11
    old Member
  • 1,687 Thanks
  • 976 posts
Posted September 29, 2013 - 05:05 PM
Cub cadet 582 tran with 30 mm axles. Use it for pulling. we pull on a stone boat, and pull around 6,500 lbs. on concrete.100_5216.jpg
Edited by Chris11, September 29, 2013 - 08:25 PM.
