Should I Treat Unleaded Fuel
17 replies to this topic
#1 Gfann OFFLINE
Gfann
  • 194 Thanks
  • 228 posts
Posted September 29, 2013 - 01:51 AM
I've been using straight unleaded fuel in my older tractors which are mainly from the 60s. I was curious if it would be better if I treated the fuel to become for leaded. Did those older garden run on leaded fuel? What I have specifically is a mid 60s Simplicity, 65 cub, and an early 60s s14 and a 67 s18 Speedex. Do any of you treat your gas if so what do you use and how well does it work?
  • JRJ said thank you
#2 EricFromPa OFFLINE
EricFromPa
  • 3,648 Thanks
  • 3,108 posts
Posted September 29, 2013 - 02:19 AM
All 1960s small engines have Hardened valve seats.There is no need for a Lead additive.Just try to use a Mid grade fuel if at all possible.89 or higher stay away from E10 Ethanol added Fuel if at all possible.
Edited by EricFromPa, September 29, 2013 - 02:25 AM.
  • Gfann and JRJ have said thanks
#3 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,769 Thanks
  • 4,261 posts
Posted September 29, 2013 - 04:17 AM
I use unleaded fuel in my 1966 JD112 - no probs
#4 Arti OFFLINE
Arti
  • 1,363 Thanks
  • 989 posts
Posted September 29, 2013 - 06:01 AM
Seems like a few drops of Marvel Mystery oil or Seafoam added to the gas works for me.
  • Utah Smitty, KC9KAS, Gfann and 1 other said thanks
#5 MH81 OFFLINE
Posted September 29, 2013 - 06:37 AM
A little Seafoam to combat the ethanol and once in a while a little quicksilver 2 cycle or MMO. Not enough to make it a smoker, but enough to give it a little lube.
#6 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted September 29, 2013 - 06:42 AM
That's the recipe right there.  :thumbs:
Ben W.
  • MH81, KC9KAS, Gfann and 1 other said thanks
#7 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted September 29, 2013 - 06:48 AM
You should still use a fuel stabilizer if you don't run your tractors often or when storing them for any more than a month or so.
#8 NUTNDUN OFFLINE
  • 10,339 Thanks
Posted September 29, 2013 - 07:01 AM
We usually use seafoam. For the ones that are going to sit for a long time I usually try to drain the gas but don't always remember to.
#9 Kyocum OFFLINE
Kyocum
  • 299 Thanks
  • 424 posts
Posted September 29, 2013 - 07:08 AM
I use a product called Startron and it is a great additive. It combats ethanol issues and I have found my engines start much better in the winter time. I think the best feature is it gives gasoline a 2 year shelf life. I myself have never had any issues with E-10 fuel but just the fact it gives it a 2yr shelf life I'm sold. Been using it for about 5 yrs.
  • Utah Smitty, Gfann and JRJ have said thanks
#10 powerking56 OFFLINE
powerking56
    Collector of stuff
  • 909 Thanks
  • 1,805 posts
Posted September 29, 2013 - 07:27 AM
My formula is mid grade unleaded with a dose of marine Sta-bil, and a cap full of Seafoam and a cap full of Marvel Mystery Oil for each 1 & 1/2 gals of gas.  The only regular and mid-grade we can get has 10% ethanol so I am stuck combating the effects of ethanol.  So far my "blend" has worked well with minimal carb fouling issues and good cold weather starting in both my newer mowers and snow blower and my older tractors.
#11 KC9KAS ONLINE
KC9KAS
  • 5,383 Thanks
  • 4,690 posts
Posted September 29, 2013 - 09:22 AM
I add 16 oz can of SEAFOAM to 5 gallons of gasoline every time I refill the can.
I use this fuel for the GT's, and the fuel for the 2 cycle weedeater, saw and leaf blower.
I also use the SEAFOAM in my motorcycles. Very good product!
#12 thirdroc17 OFFLINE
thirdroc17
  • 37 Thanks
  • 91 posts
Posted October 03, 2013 - 06:00 PM
Just a curiosity question.  With all the blends and additives some of you are adding, have you ever added up the final cost per gallon?   Some of that stuff is expensive, and you must be getting close to the $10 a gallon mark on the final mixtures.
I run a couple ounces of StaBil in 5 gallons because sometimes it sits a long time.  Like a year or more in some the lesser used tractors.  Never had any problems.
As for the original question of lead, all gasoline was originally unleaded.  It was around the 70's sometime the oil giants learned they could throw lead in crap gas and get higher octane and higher profits.   Then the car companies figured out they could get cheap on the internal parts because of the lead, and create higher profits.  When unleaded first "came out" it was actually a step backwards in time.
  • sacsr and Gfann have said thanks
#13 KennyP ONLINE
  • 38,195 Thanks
  • 45,842 posts
Posted October 03, 2013 - 06:17 PM
I chose Seafoam over Stabil. 1 ounce per gallon and I'm done. Had them start 18 months later with this mix using unleaded fuel!
  • Utah Smitty, dogsoldier, KC9KAS and 1 other said thanks
#14 KC9KAS ONLINE
KC9KAS
  • 5,383 Thanks
  • 4,690 posts
Posted October 04, 2013 - 07:26 PM
"Just a curiosity question. With all the blends and additives some of you are adding, have you ever added up the final cost per gallon? Some of that stuff is expensive, and you must be getting close to the $10 a gallon mark on the final mixtures."
I just figured th cost per gallon with the SEAFOAM, and it is $5.00 +/- a gallon.....Depending on the fuel cost on any given day.
This is a small price to pay for the satisfaction of knowing this mixture will HELP my engines instead of causing damage/problems using stratght fuel with 10% ethanol.
It is a conspiracy that we have to add these extras to the fuel in the 1st place!
  • Utah Smitty and Gfann have said thanks
#15 Utah Smitty OFFLINE
Utah Smitty
  • 1,701 Thanks
  • 1,781 posts
Posted October 07, 2013 - 10:13 PM
Some gas may have been unleaded in the old days, but I worked in a Sinclair Station (western US gasoline chain) in the late 60s.  The pumps were the Tokheims that used a hand crank to reset the dials before you started pumping.  I still remember there was a large placard beneath the hole for the fuel nozzle that stated the fuel contained Tetraethyl lead.
FWIW,
Smitty
  • Gfann said thank you
