Massey Hall Is Needing An Addition.
113 replies to this topic
#76 IamSherwood OFFLINE
  • 8,395 Thanks
Posted October 27, 2013 - 12:30 AM
I don't have one of those. :oh_shucks:  It would have to be a good (real good) cold
weather runner.
#77 KennyP ONLINE
  • 40,989 Thanks
  • 47,156 posts
Posted October 27, 2013 - 06:07 AM
It's looking good, Will!
  • IamSherwood said thank you
#78 Sawdust OFFLINE
Sawdust
  • 6,155 Thanks
  • 3,549 posts
Posted October 31, 2013 - 11:56 AM
Being a carpenter I have really been enjoying your project. I like your choice of materials & the design. I hate watching people build cutting corners knowing the structure won't last. On the gang plank thought...Have you considered using a dumb waiter. Imagine your gang plank laying flat on the ground. A cable attached at each top corner running to the top of the opening & through the wall on a pulley. From this pulley would be the other end of the cable with a weight balanced to the planks weight on the inside of the wall. You may not have enough travel before the weight hits the floor. If this is the case you could cut an opening in the floor so the weight drops below the floor. All the mechanics would be inside & simple to lower & raise with the right balance. There would be no noise of a gas engine....not that I don't like the noise & fragrance of a good running engine.  :D You could also lock it easily once you have it raised & closed.
  • Texas Deere and Horse, IamSherwood and oldedeeres have said thanks
#79 IamSherwood OFFLINE
  • 8,395 Thanks
Posted October 31, 2013 - 07:46 PM
I got a fair bit done in the last couple of days.
Windows in the back wall, and gangplank door reinstalled,
using the old trailer winch system. Sorry Jim, I beat you to it. :D
I then removed the siding off the original wall. My original plan was to remove the lower
horizontal strapping, leave the shelves, and mirror them in the new room. I changed my mind
as it looked too busy, for what the shelves where accomplishing.
So I removed all the shelves, left the quarter point posts in temporarily, and the
added crutches to support the new ridge beam. I also gusseted the ridge beam
to the posts, and added a collar tie.
Then I got started on the new shelf.
  • olcowhand, MH81, Alc and 10 others have said thanks
#80 KennyP ONLINE
  • 40,989 Thanks
  • 47,156 posts
Posted October 31, 2013 - 08:13 PM
Looks good, Will. I like the open look of it!
  • IamSherwood and oldedeeres have said thanks
#81 IamSherwood OFFLINE
  • 8,395 Thanks
Posted October 31, 2013 - 08:19 PM
Thanks Kenny.
Much better that way, isn't it. I'll put 1" oak on as the shelf
material, just where the wheels are.
If it looks like the 3 horizontals are going to sag, with the
weight of the MF5, 6, and 832 on it, I'll run some 1/4"
chain up to the ridge beam.
  • Texas Deere and Horse, KennyP and oldedeeres have said thanks
#82 oldedeeres OFFLINE
oldedeeres
  • 10,495 Thanks
  • 5,099 posts
Posted November 01, 2013 - 12:02 AM
Like Kenny said.   I have found clutter can happen quick enough by accident, no point in building it in. What you've done really looks great.
#83 olcowhand OFFLINE
  • 42,900 Thanks
  • 31,942 posts
Posted November 01, 2013 - 08:57 AM
I think it's a fantastic building!  Great work as we've learned to expect from you Will!   :thumbs:
#84 Sawdust OFFLINE
Sawdust
  • 6,155 Thanks
  • 3,549 posts
Posted November 01, 2013 - 10:48 PM
Looking good Will. I like the winch set up for the gang plank.
#85 Alc ONLINE
  • 7,257 Thanks
  • 7,597 posts
Posted November 02, 2013 - 06:38 AM
I'm sure I'm like others with neither the skills or $$  ( lol )to build such a great building but we watch and read in aw of the work you and others do and maybe just maybe we'll pickup a little storage or building tip that will help us out , thanks for the thread .
#86 MH81 OFFLINE
  • 29,979 Thanks
Posted November 02, 2013 - 06:44 AM
Had so much going on, I missed the last update.
Looking fantastic Bud. Almost like you knew what you were doing... :poke:
#87 IamSherwood OFFLINE
  • 8,395 Thanks
Posted November 03, 2013 - 06:35 PM
Got the shelving done, floor done, and some furniture moved in.
Go figure. Elf took 2 parking spots for himself. What does he think he is?
A Benz?
  • olcowhand, DH1, Texas Deere and Horse and 6 others have said thanks
#88 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted November 03, 2013 - 06:41 PM
Looks great Will. Do you secure the tractors down to the shelf to prevent them from rolling off?
#89 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,452 Thanks
  • 5,621 posts
Posted November 03, 2013 - 06:43 PM
Looks great Will, lots more space, Good Stuff.
BTW what this little one sitting up here?
I don't remember seeing it at Massey Hall before.
#90 IamSherwood OFFLINE
  • 8,395 Thanks
Posted November 03, 2013 - 07:13 PM
Oops, I forgot to put the chokes on that little MF24s. (but it's in gear)
The other ones have wedge blocks screwed to the shelves.
That's the one from Kenora, that you got me on to in Aug. last year. I've been waiting
for it to get here. It arrived this morning. My daughter was driving home from BC, so I got her
to stop, and stuff it in the trunk. :D She was pretty happy about that.
  • MH81, Texas Deere and Horse, wvbuzzmaster and 4 others have said thanks
